Using gmopccapy with an XHC-HB04 pendant
- franstrein
06 Feb 2019 09:55 #125793
by franstrein
Using gmopccapy with an XHC-HB04 pendant was created by franstrein
Hi all,
I finally extended my gkmoccapy setup with an XHC-HB04 MPG Pendant. Following the instructions found on the forum, I have this working now and I programmed most buttons to my needs.
But a very basic question remains:
When gmoccapy presents a dialog or message on the screen, e.g. for a tool change, I still need to click the OK button on my screen. Would there be a HAL command I could issue from a button on my MPG in order to close that dialog in gmoccapy?
That would make live easier.
Thanks,
Frans
Thanks,
Frans
06 Feb 2019 16:07 #125818
by newbynobi
Replied by newbynobi on topic Using gmopccapy with an XHC-HB04 pendant
Not at the moment, but that is a good idea,
i will see, if i find time to include such a pin, i just use the enter button of my keyboard?
Norbert
Norbert
- franstrein
06 Feb 2019 19:54 #125855
by franstrein
Replied by franstrein on topic Using gmopccapy with an XHC-HB04 pendant
Hi Norbert,
Thanks for the quick response (as always).
Would be nice if you could do something on this, obvious not in a hurry. However I am still on Linux 2.7, with GMOCCAPY 1.5.9....
But in case you know of a way that I can program a button definition in the pendant configs, to raise an "Enter" keyboard command, that would be good enough maybe.
Thanks,
Frans
Thanks,
Frans
16 Sep 2021 09:36 #220779
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Using gmopccapy with an XHC-HB04 pendant
Sorry for using an old thread but could you share your config files for gmoccapy and the pendant please?
Regards
Marius
www.bluearccnc.com
