toolsensor below Machine Surface
08 Sep 2021 17:16 - 08 Sep 2021 17:17 #219975
by Clements
toolsensor below Machine Surface was created by Clements
Hi
i am trying to get met tool sensor to work in 2.8+Gmocappy
the sensor is mounted below the surface of the machine table
in the settings tab I can specify the X and Y position.
The Z-value only a positive number can be entered. Manually changing the xx.pref file doesn't make a difference.
In the past (v2.7) my setup has worked this way, I only can't seem to set it up now.
any suggestions?
any suggestions?
Last edit: 08 Sep 2021 17:17 by Clements.
14 Sep 2021 17:42 #220633
Replied by andypugh on topic toolsensor below Machine Surface
I have moved this to the Gmoccapy section in the hope that Norbert will see it.
