Ver 3.1.3.10 Screen won't re-size
18 Sep 2021 08:55 #220982
by rider-83
Ver 3.1.3.10 Screen won't re-size was created by rider-83
I've recently upgraded Lcnc to the latest version of 2.9. As a result Gmoccapy has moved up from 3.1.3.1 to 3.1.3.10
For some reason the gmoccapy screen won't adjust and re-size to my monitor size and the out side icons are beyond the boundaries of the monitor.
I can't seem to find a way to resolve this. Can anyone help ?
- robertspark
- Thank you received: 216
18 Sep 2021 12:05 #220989
by robertspark
Replied by robertspark on topic Ver 3.1.3.10 Screen won't re-size
what screen size are you running?
what make, and model of monitor?
(is it not possible to adjust the monitor to the resolution that works best with Gmoccapy?)
18 Sep 2021 12:55 #220997
by rider-83
Replied by rider-83 on topic Ver 3.1.3.10 Screen won't re-size
Make is unknown as it is a flat industrial chassis.
I've tried various resolutions,etc but I've reverted back to the max I can select at 1024.
Everything worked perfectly well until this update, so something has changed.
I've since discovered that ALL the gui's via Lcnc do the same, not just Gmo.
All the other linux apps work just fine. It's unique to Lcnc
- robertspark
18 Sep 2021 14:23 - 18 Sep 2021 14:26 #221002
by robertspark
another dependency missing?
OpenGL or something like that (I really have no clue what could be missing)
Have your tried selecting one of the TK GUI's to see what they look like?
__________________________________
Please DONT cross post
forum.linuxcnc.org/38-general-linuxcnc-q...screen-won-t-re-size
Last edit: 18 Sep 2021 14:26 by robertspark.
18 Sep 2021 14:27 #221004
by rider-83
I've tried :
Axis
Gmoccapy
& Dragon
All these behave the same.
Axis
Gmoccapy
& Dragon
- robertspark
18 Sep 2021 16:05 #221017
by robertspark
open a terminal, type:
linuxcnc
when the dialog pops up, go to sim, and select
tklinuxcnc
and then select
tklinuxcnc
is it now resizable?
tk is kind of the most basic of screens.... it does not rely on much....
linuxcnc
tklinuxcnc
and then select
tklinuxcnc
18 Sep 2021 19:02 #221033
by rider-83
Thanks,
I'll give it a try in the morning
19 Sep 2021 10:53 - 19 Sep 2021 11:13 #221076
by rider-83
Tried it, and that worked fine.
I tried Gscreen, and that resized perfectly as well.
I have also noticed that part of the black 'Plot' window remains 'stuck' on the screen when you swap through different option screens or try to move the Gmo window around the screen with the mouse. It sits there like a shadow and only goes away when you closed down Gmo
Last edit: 19 Sep 2021 11:13 by rider-83.
19 Sep 2021 11:27 #221077
by rider-83
More errors with Gmo,
Tried to make some progress with with my original work before it all went south after the upgrade, and now I have more traceback errors whilst running Gmo.
It seems like one step forward,two back and three forward. Very frustrating
I don't know what to do here to get this simple lathe working again.
- robertspark
19 Sep 2021 11:40 #221078
by robertspark
need to know what the messages are
still suspect you have dependencies missing
Time to create page: 0.083 seconds
