linuxcnc classicladder ATC 12 tool
22 Sep 2021 00:20 #221309
by Ingo
linuxcnc classicladder ATC 12 tool was created by Ingo
Guys, could someone please give me a light, I'm not able to make my ATC12 rotate with the M6, I put the tool number, ex. T3 and already starts to rotate in position. Another thing, I'm using Gmoccapy and the tool number doesn't change it's locked, after you make the change it doesn't show the current number. I've been racking my brain for a couple of weeks if anyone can give a tip I would be very grateful.
01 Oct 2021 13:05 #221951
Replied by andypugh on topic linuxcnc classicladder ATC 12 tool
Are you using the tool-prep or tool-number hal pins?
05 Oct 2021 05:18 #222246
by newbynobi
Replied by newbynobi on topic linuxcnc classicladder ATC 12 tool
Did you read the gmoccapy dokumentation?
Are the corresponding gmoccapy hal pins connected?
Norbert
Norbert
06 Oct 2021 09:28 #222341
by alkabal
Replied by alkabal on topic linuxcnc classicladder ATC 12 tool
Hello
I know nothing about classicladder but i noticed he use the hal_manualtoolchange from axis :
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Time to create page: 0.197 seconds
