When Linux CNC runs G code, the X axis has only one direction
18 Nov 2021 16:55 #226892
by tuzki
Hello everyone.
Today I use LinuxCNC to run the sample G code. I found that LinuxCNC has only one direction on the X axis during operation, and it cannot correctly execute the positive and negative directions in the G code.
When I am not running the G code, I use the GUI to manually move the X axis, and the X axis works normally.
The parallel port control board I use controls an X axis. There is no motor connected to the Y-axis and Z-axis, because I only have a stepper motor.
I use gmoccapy GUI.
I don't know where is the problem. Can someone help me. thanks.
I use gmoccapy GUI.
18 Nov 2021 17:10 #226893
by BigJohnT
Replied by BigJohnT on topic When Linux CNC runs G code, the X axis has only one direction
Sounds like your G code is faulty. A sample of what your running would help.
JT
JT
18 Nov 2021 17:19 #226894
by tuzki
Replied by tuzki on topic When Linux CNC runs G code, the X axis has only one direction
correct. I changed other sample G codes, some of the directions are not processed normally, and some are normal
I will record the G codes that I can't run normally and send them to the forum. Maybe it is normal when other people run these G codes.q(≧▽≦q)
19 Nov 2021 17:23 #227003
by tuzki
Today, I tried the programs that had problems yesterday, and I found that the programs that have problems can run normally.
Kind of weird
Kind of weird
Time to create page: 0.207 seconds
