Differing analogue outputs in forward and reverse spindle ??
27 Nov 2021 19:33 #227771
by john11668
Having sorted My back/ front tool problems and spindle reversing issues , both now seem to be working well, but I have a spindle speed discrepancy between spindle Fwd and spindle Rev ( Machine is a Boxford TCL125 with original DCmotor and Sprint DC driver )
1) I select spindle fwd , indicates S 300 rpm and I get a speed of 372rpm at 2.38 v analogue giving an armature voltage of 34.3v
2) If I select Reverse it shows S -300 rpm but I only get 312 rpm and an analogue input of 2.08 giving AV of 29.3. (so a significant difference)
3) I have to increase the selected reverse revs to S -345 to get the same speed output of 372 with -34.3v from 2.4v analog input ..
From readings 1 and 3 it seems to me that my motor is responding correctly to the driver voltages but the analog signal is not the same in fwd and rev despite the same spindle speed being called for.
Now I know that i can change the scale number in hal to bring actual speed into line with selected speed, but cant see a how I can choose a different scale factor for forward and reverse, so I really need the analogue outputs to be the same in both modes .
It is puzzling that they are not .
Is there any way to adjust the analogue outputs for each respective mode ?
28 Nov 2021 10:30 #227807
Replied by rodw on topic Differing analogue outputs in forward and reverse spindle ??
I think you could use a mux2 component followed by a mult2 component.
use the spindle direction pin as the mux select signal
setp the mux inputs to be 1.0 and your scaling factor, say its 1.25
connect the mux output to a mult2 input
connect the spindle speed to the other input.
So in forward you will get the actual signal. but if you select reverse, the signal will be 125% of the forward signal (in our example)
Happy coding! You'll be an expert with hal by the end.
The following user(s) said Thank You: john11668
28 Nov 2021 14:44 #227811
by john11668
Replied by john11668 on topic Differing analogue outputs in forward and reverse spindle ??
Will look into that Rodw although the process is not coming over to me quite clearly yet . Maybe it will become apparent when I research mux and mult in the manual.
Initially though it seems like a bit of a fudge . Is there no way to ensure equal pwm outputs in fwd and reverse , and indeed why do they differ in the two modes .
09 Dec 2021 06:13 - 09 Dec 2021 06:14 #228687
by newbynobi
Replied by newbynobi on topic Differing analogue outputs in forward and reverse spindle ??
Why not to use a scale component and set the offset and Gain values?
By the way, this issue is not gmoccapy related, as well as it was not the back/front tool part.
It might be better to post you threads in better topics.
Scale component
Scale component
Last edit: 09 Dec 2021 06:14 by newbynobi.
