Jog override encoder bug?
- Firehunter
22 Dec 2021 20:00 #229757
by Firehunter
Jog override encoder bug? was created by Firehunter
I'm using two EC11 encoders for setting jog speed and changing feed, rapid and spindle overrides (depending on the current mode). These are connected to the gmoccapy override pins. The encoders both work correctly as I can see the counts values decrease and increase in halshow. But everytime I change the spindle override and after that the jog (or feed/rapid) override, the latter makes a big jump. For example, the normal jog adjustment is 15mm/min per encoder count, after turning the spindle override encoder 1 or more clicks, the jog speed jumps 30 to 360 units. Most of the time even in the wrong direction.
When I use the halui override pins instead of the gmoccapy pins, everything works correctly . But halui has no jog override pins. I also tested with the two encoder count signals switched, but this doesn't change anything. The spindle override percentage always change 1%. The other override jumps.
My custom_postgui.hal:
net feed-override => gmoccapy.jog.jog-velocity.counts gmoccapy.feed.feed-override.counts gmoccapy.rapid.rapid-override.counts
net spindle-override => gmoccapy.spindle.spindle-override.counts
# Only enable jog override in manual mode
net manual-mode => gmoccapy.jog.jog-velocity.count-enable
# Only enable feed and rapid override in auto mode
net auto-mode => gmoccapy.feed.feed-override.count-enable gmoccapy.rapid.rapid-override.count-enable
# Always enable spindle override
setp gmoccapy.spindle.spindle-override.count-enable 1
03 Jan 2022 19:55 #230674
by newbynobi
Replied by newbynobi on topic Jog override encoder bug?
You can not connect one physical encoder to several encoder inputs!
The encoder counts and when you switch to another encoder, the new value will be applied!
I.e. The jog encoder counts is 100 and the feed override counts is 100 and the jog vel counts is 100 after start, when you change now the encoder counts connected to jog vel counts to be 50 and you now change to feed override counts, that will be set automatically to 50 resulting in a big jump!
Norbert
Norbert
- Firehunter
04 Jan 2022 10:12 #230743
by Firehunter
Replied by Firehunter on topic Jog override encoder bug?
But the jump happens after I change the spindle override. I'm not switching encoders.
11 Jan 2022 09:00 #231414
by newbynobi
Yes, that is because you have connected all encoder inputs to one encoder in your hal file.
Time to create page: 0.117 seconds
