Shift key to push button for jogging
14 Jan 2022 08:04 #231736
by Wischi
Shift key to push button for jogging was created by Wischi
Hello,
I am currently trying to set up a control panel with push buttons for jogging. I use a arrangement of 3x3 buttons. The center button is going to be a rapid override. The same function as holding the shift key while jogging. Since there is no hal pin for this function I have searched the forum and google but couldn't find a solution.
So far I have tried changing the gmoccapy.jog.jog-velocity.direct-value to my max speed while the button is pressed and upon release restore the old value. But changing the speed while jogging didn't work.
Next thing I tried was adding a hal input to the shift input in the source of gmoccapy, but again I would have to press the button before jogging to get it to work. Or maybe I am just not skilled enough with phyton to do it correctly.
The last resort would be a modified keyboard, but I think this would be kind of cheating, it should be possible with software only (I hope).
I appreciate any ideas on how this could be done.
Thanks.
Thanks.
14 Jan 2022 10:59 #231742
by newbynobi
Replied by newbynobi on topic Shift key to push button for jogging
Rapid Override and jog with shift key are differnt cases.
IMHO while jogging and then pressing the shift key did never lead to faster jogging.
Have you tried that with your normal keyboard?
Norbert
Norbert
14 Jan 2022 13:27 #231755
by Wischi
Replied by Wischi on topic Shift key to push button for jogging
Maybe I got the wrong name, lets say velocity override instead of rapid override. When I try it with my normal keyboard the velocity changes from number set at the slider to the max velocity set in the ini.
14 Jan 2022 23:20 #231817
Replied by cmorley on topic Shift key to push button for jogging
The jogging process is separate layer from the limiting of rapid or feed rates.
Max velocity limiting doesn't even affect jogging speed usually (it may in Gmoccapy)
The shift key works by setting the internal Gmoccapy jog speed variable higher, so that when the jog key is pressed it either uses the normal jog speed or the highest jog speed.
Linuxcnc it's self doesn't keep any global variable of jog speed - every UI keeps it's own.
So to get this to work as you wish requires access to Gmoccapy's internal data or
use separate jogging code say using gladevcp panel or use a keyboard stroke emulator or use a separate keyboard.
Chris
Chris
Time to create page: 0.073 seconds
