GUI Unresponsive when using AMD video card
30 Jan 2022 06:33 #233517
by a.smith
GUI Unresponsive when using AMD video card was created by a.smith
I installed an old Radeon HD 6750 card and it is causing Gmoccapy to freeze if I interact with the gcode preview window or controls. Clicking any buttons or touching the preview window to pan or zoom locks up the entire Gmoccapy interface indefinitely. The system will continue to mill as if nothing happened and has to be killed with the e-stop. The freeze also occurs in the default Gmoccapy sim, but does not occur in Axis. The system behaves normally when running onboard graphics.
Is there anything I might try to resolve this?
My system is as follows:
Linuxcnc 2.8.2 preempt-rt
The system is running the "radeon" kernel module and driver
Mesa 7i76e
Supermicro x9scl motherboard
Mesa 7i76e
- Online
- Thank you received: 5934
07 Feb 2022 20:16 #234285
Replied by tommylight on topic GUI Unresponsive when using AMD video card
Check if any Radeon drivers are blacklisted and try enabling them.
Beware that might leave you with a black screen.
Time to create page: 0.097 seconds
