Ignore limits does not work on start up
03 Feb 2022 12:57 #233873
by prochj51
Ignore limits does not work on start up was created by prochj51
when I turn on the machine and the machine sits on limit switch, the Ignore limits check box cannot be toggled.
When I hit limit switch during normal operation after machine is homed and stuff I can use Ignore limits without problems.
Is this expected behaviour?
Jiri
Jiri
04 Feb 2022 05:59 #233945
by newbynobi
Replied by newbynobi on topic Ignore limits does not work on start up
I thought I corrected that bug already
What release do you use?
What if you toggle the e-stop switch?
Norbert
Norbert
08 Feb 2022 22:43 #234361
by HansU
Replied by HansU on topic Ignore limits does not work on start up
A fix is provided here: github.com/LinuxCNC/linuxcnc/pull/1453
16 Feb 2022 14:33 #235043
by prochj51
Replied by prochj51 on topic Ignore limits does not work on start up
Sorry,
I was using the version before fix.
Thank you.
Jiri
Thank you.
Jiri
18 Feb 2022 22:05 #235285
by HansU
No worries, you couldn't know that - it's still an open pull request. But it would be nice if you could tell us if this works for you.
Time to create page: 0.124 seconds
