Error when KDE desktop with Gmoccapy
  • SanzuiWorks
  • SanzuiWorks's Avatar Topic Author
  • Senior Member
  • Senior Member
13 Mar 2022 17:34 #237134 by SanzuiWorks
Error when KDE desktop with Gmoccapy was created by SanzuiWorks
I get an error when I start Gmoccapy in KDE Desktop.
Is there a way around this?No problem with xfce
KDE gives good latency results in my environment. Switching to Xfce causes a fatal delay.
LinuxCNC 2.8.2  Debian 10 Buster PREEMPT-RT
13 Mar 2022 18:10 #237137 by HansU
Replied by HansU on topic Error when KDE desktop with Gmoccapy
See the forum.linuxcnc.org/gmoccapy/33045-error-...capy?start=20#237136
So try to install and enable another icon theme.
On my machine Gmoccapy only works with the icon themes GNOME and Tango.
  • Moderator
  • Moderator
13 Mar 2022 18:25 #237138 by tommylight
Replied by tommylight on topic Error when KDE desktop with Gmoccapy
That seems interesting and warrants a bit more investigation, whenever i might have a bit of time.
I use Mate Desktop Environment mostly, but i do use XFCE on low end PC's and laptops, besides being a bit more snappy XFCE never seemed any better for latency.
Hansu has some good advice, some applications just do not run properly on different environments due to appearances and icon themes.
  • SanzuiWorks
  • Senior Member
  • Senior Member
13 Mar 2022 23:25 #237161 by SanzuiWorks
Replied by SanzuiWorks on topic Error when KDE desktop with Gmoccapy
Thanks to you,
I was able to safely avoid the error by installing gnome-icon-theme.
Moderators: newbynobiHansU
Time to create page: 0.230 seconds
