Key binding
23 Mar 2022 08:48 #238084
by daiman444
Key binding was created by daiman444
hello colleagues. can someone suggest or share code example how to make hotkeys for gmoccappy ?
23 Mar 2022 13:45 - 23 Mar 2022 13:46 #238102
by newbynobi
Replied by newbynobi on topic Key binding
It is done in
look for
around line 2936
Norbert
linuxcnc/src/emc/usr_intf/gmoccapy/gmoccapy.py
look for
def on_key_event(self, widget, event, signal):
around line 2936
Norbert
Last edit: 23 Mar 2022 13:46 by newbynobi.
The following user(s) said Thank You: daiman444
14 Apr 2022 09:32 #240223
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Key binding
Thanks Norbert. I was just going to ask the question.
Regards
Marius
www.bluearccnc.com
16 Apr 2022 06:43 #240376
by mariusl
Regards
Marius
www.bluearccnc.com
For interest sake.
At about line 3077 you can add these lines to add keys for the A axis.
elif keyname == "Page_Down" or keyname == "KP_Page_Down":
button_name = "z-"
if signal:
self._on_btn_jog_pressed(None, button_name, fast)
else:
self._on_btn_jog_released(None, button_name)
elif keyname == "Home" or keyname == "KP_Home":
button_name = "a+"
if signal:
else:
elif keyname == "End" or keyname == "KP_End":
button_name = "a-"
if signal:
else:
button_name = "z-"
if signal:
else:
button_name = "a+"
if signal:
else:
button_name = "a-"
if signal:
else:
Regards
Marius
www.bluearccnc.com
Time to create page: 0.255 seconds
