Rotary Jog Speed
26 Mar 2022 17:07 #238411
by rajsekhar
Rotary Jog Speed was created by rajsekhar
Hello everyone..
I am using step config wizard with XYZA machine. Software 2.8.2 buster.
Now when I put A axis speed value in step-config, it is in degree/sec. I put 56 degree/s i.e 9.33 rpm and testing the axis rotates in that speed.
But during use in GMOCAPPY, the same value shows with degree/min at max jog speed i.e 56 degree/min (0.16 RPM) which is very slow in fact.
How to solve??
How to solve??
26 Mar 2022 21:14 #238427
Replied by cmorley on topic Rotary Jog Speed
can you post your config files?
15 Apr 2022 17:07 #240325
by rajsekhar
Replied by rajsekhar on topic Rotary Jog Speed
Attached
19 Apr 2022 22:14 #240691
Replied by andypugh on topic Rotary Jog Speed
Try changing these values in your iNI file:
[DISPLAY]
DEFAULT_ANGULAR_VELOCITY = 5.60
MIN_ANGULAR_VELOCITY = 0
MAX_ANGULAR_VELOCITY = 56.00
(I am a bit puzzled, in that going by the date in the INI file, you have been putting up woth this for three years?)
[DISPLAY]
30 Apr 2022 07:51 #241702
by rajsekhar
the motherboard has some issue with the battery, date is not stored
