How to hide an Axis for display and homing
14 Apr 2022 09:36 - 14 Apr 2022 09:40 #240225
by mariusl
Regards
Marius
www.bluearccnc.com
How to hide an Axis for display and homing was created by mariusl
I have a textile cutter that has X, Y and A (rotary) axis. I need to hide the Z axis with buttons and DRO and homing from the GUI. What is the best way to do this?
Regards
Marius
www.bluearccnc.com
Last edit: 14 Apr 2022 09:40 by mariusl.
14 Apr 2022 10:19 #240226
by newbynobi
Replied by newbynobi on topic How to hide an Axis for display and homing
If you configure an XYA machine, all other axis / joints will be invisible.
What have your configured in your INI File?
Norbert
Norbert
14 Apr 2022 10:44 #240227
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic How to hide an Axis for display and homing
In the INI under [DISPLAY] - geometry = xya
makes no difference
If I change [TRAJ] - coordinates = XYA the system takes a long time to start and is very sluggish and the jog buttons are missing
makes no difference
Regards
Marius
www.bluearccnc.com
14 Apr 2022 10:48 - 14 Apr 2022 10:55 #240228
by mariusl
Regards
Marius
www.bluearccnc.com
I found this in the debug log to console
***** GMOCCAPY INFO *****this is not a usual config
we miss one of X , Y or Z axis
We will use by axisletter ordered jog button
**** arrange JOG button by axis
/usr/bin/gmoccapy:311: GtkWarning: Invalid icon size 48
The system is unusable as it does not seem to find the limit switches and cannot start up. There is no limit switches setup only home switches. After a while it will bom out.
Regards
Marius
www.bluearccnc.com
Last edit: 14 Apr 2022 10:55 by mariusl.
14 Apr 2022 15:31 #240237
by HansU
Replied by HansU on topic How to hide an Axis for display and homing
Which LinuxCNC version are you running?
14 Apr 2022 15:59 #240240
by mariusl
Regards
Marius
www.bluearccnc.com
The latest 2.8 running on stretch
Regards
Marius
www.bluearccnc.com
