gmoccapy.toolchange-change Not Found
01 Jul 2022 17:20 #246383
by soram
gmoccapy.toolchange-change Not Found was created by soram
Guys,
Hope you can help - I'm pulling my hair out at this stage. I have been through all the posts related to this from previous years and all the manuals but I cannot for the life of me get this pin to connect
I have the following line in my custom_postgui.hal file but it is not finding gmoccapy.toolchange-change (Or any of the other 3 required)
If I comment it out and go to the hal meter on the running application I can see the signal but my postgui will not link to it. I have a generated config from with a MESA board I am just hacking to put in the probe code. Is there something in the CONFIG I need to untick / tick before I add these lines? Or anything else I might be missing? I've been through the INI and main HAL files but nothing jumps out at me!
Any help appreciated
01 Jul 2022 17:32 #246385
by soram
Replied by soram on topic gmoccapy.toolchange-change Not Found
OK - apologies but I went through the files again and found the issue......
It appears that the PNCCONF tool inserts the line below at the top of the main HAL file
source postgui_call_list.hal
So this is called before everything else
If I delete this line it works. Am I missing something here? The postgui_Call_list.hal is also declared in the HAL section of the INI.....
Cheers
Cheers
01 Jul 2022 18:37 #246389
Replied by cmorley on topic gmoccapy.toolchange-change Not Found
What version of linuxcnc are you using?
03 Jul 2022 10:17 #246493
Replied by andypugh on topic gmoccapy.toolchange-change Not Found
No, it seems that you have probably found a fix to a PNCCONF bug. (Which is why Chris is asking about LinuxCNC versions, I would guess he wants to check if it's a fixed issue or not)If I delete this line it works. Am I missing something here?
04 Jul 2022 09:42 #246565
by soram
OK - not sure if this is correct but the splash screen says 2.8.2-11 and some other numbers I'm not quick enough to write down. I may get to it later. Is there somewhere else to read it?
It was the Debian / LinuxCNC install image that was on the websites.
GMOCCAPY is 3.1.3.8
This is in the INI:
# Generated by PNCconf at Fri Jul 1 11:50:58 2022
# Using LinuxCNC version: 2.8
# overwritten when you run PNCconf again
GMOCCAPY is 3.1.3.8
This is in the INI:
04 Jul 2022 09:45 #246566
by soram
This is the top of the HAL with the offending entry:
# Generated by PNCconf at Sun Jul 3 11:35:31 2022
loadusr -Wn pyvcp pyvcp -c pyvcp [DISPLAY](PYVCP)
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt hostmot2
Time to create page: 0.078 seconds
