Lathe, tooltip radius
02 Jul 2022 14:42 #246442
by DoWerna
Lathe, tooltip radius was created by DoWerna
Probably a stupid question. Tool tip radius, is labelled with "diameter" in the tool table. But I have to enter the radius, not the diameter, right?And this is independent of whether the machine works in G7 or G8 or not?ThanksW
03 Jul 2022 10:33 #246495
Replied by andypugh on topic Lathe, tooltip radius
I am pretty sure that, even for a lathe, the tool table entry is the diameter (or, more pedantically, twice the tip radius)
G7 / G8 has no bearing on the _tool_ rad/dia.
The following user(s) said Thank You: DoWerna
04 Jul 2022 11:14 #246573
by DoWerna
Replied by DoWerna on topic Lathe, tooltip radius
Did a bit of testing on the machine.
That's right, twice the radius must be specified.
Time to create page: 0.073 seconds
