Gmoccapy didnt works in MDI and Automatik
25 Aug 2022 06:39 #250376
by CNC_Tux
Gmoccapy didnt works in MDI and Automatik was created by CNC_Tux
Dear Community,
i struggle with a problem in Gmoccapy ( Debian Buster 10.10; Preemt Kernel; LinuxCNC 2.8.3 )
I made a machine configuration with PnCConf ( standard X,Y,Z and Spindle on a Mesa 7I76e ).
in Manual mode is running Spindle, X axis, Y axis ( Z axis is delited in INI and Hal )
After homing of X and Y axis, i cant change to Automatic or MDI Mode.
I didnt understand why.
I test a Sim version of Gmoccapy ( a sample inside of LinuxCNC ) is exactly the same problem.
Is somebody there, to can support me to fix thisĀ problem? Or have anyone an idea whats the problem?
Thank you so much in advance.
Cheers
Reinhard
Cheers
Reinhard
25 Aug 2022 11:27 - 25 Aug 2022 11:28 #250395
by mgm
Replied by mgm on topic Gmoccapy didnt works in MDI and Automatik
Please post hal and ini file
Last edit: 25 Aug 2022 11:28 by mgm.
25 Aug 2022 16:42 #250413
by zz912
Replied by zz912 on topic Gmoccapy didnt works in MDI and Automatik
Why do you home only X and Y? You wrote, that you have X Y Z. Explain why is Z deleted.
This is correct behavior. You must home all axis.
26 Aug 2022 06:16 #250488
by CNC_Tux
Replied by CNC_Tux on topic Gmoccapy didnt works in MDI and Automatik
Good morning,
here is my HAL and INI file.
I need only axis X and Y, not more. Its a special of a retrofit of a punching machine.
Thats the reason to delete the Axis Z ind HAL and INI.
My suspect is, the Gmoccapy need a X, Y, Z axis as basic to run in MDI and Automatic.
Cheers
Reinhard
Cheers
Reinhard
26 Aug 2022 06:42 #250490
by zz912
In PNCconf is option "Require homing before MDI / Runing" unclick it.
The special aplication will need special modification or crerating GUI.
26 Aug 2022 18:18 #250540
by CNC_Tux
Hello zz912,
yes of course , you have right, thats true.
I think i found my problem right now, i readed my ini file here for few minutes ago and found two things.
geometry =xyz
Joints = 3
I think i have to change in:
geometry = xy
Joints = 2
I will check tomorrow morning.
Thank you so much for your support.
Cheers
Reinhard
geometry =xyz
Joints = 3
geometry = xy
Joints = 2
Cheers
Reinhard
27 Aug 2022 07:18 #250561
by CNC_Tux
Problem is done!
its was the Joints and geometry !!
sometimes is impossible, to see trees in the forest
Thank you so much for the support.
Cheers
Reinhard
Cheers
Reinhard
Time to create page: 0.214 seconds
