Optional Stop ( M1 )
03 Sep 2022 12:19 #251100
by CNC_Tux
Optional Stop ( M1 ) was created by CNC_Tux
Dear Community,
today i was tested some functions in Gmoccapy (LinuxCNC 2.8.3) and i was very suprised the "Optional Stop" ( for M1 ) didnt works.
The Button 7 in Auto Mode is for "Optional Blocks" ( Whatever its be, but isnt the same like for M1 ).
How can i get the function "Optional Stop"?
Thank you so much in advance.
Cheers
Reinhard
Cheers
Reinhard
03 Sep 2022 14:57 #251105
Replied by cmorley on topic Optional Stop ( M1 )
Were you trying to change optional stop while the program was running?
That is not supported in linuxcnc.
04 Sep 2022 06:08 #251154
by CNC_Tux
Replied by CNC_Tux on topic Optional Stop ( M1 )
Hello cmorley,
it is doesnt matter if i press the button while is the program is running or before, the result is the same.
I took a look in the hal, the button works on "Optional Blocks" not at M1
A hal pin is there, with the name "Optional Stop".
What kind of function have "Optional Blocks" ???
04 Sep 2022 06:45 #251155
optional blocks is a way to select lines of code that can be optionally run.
It again can also only be preset before running.
but Yes I don not see away to set optional stop in gmoccapy.
In master branch I do see commented out code to toggle it though.
I'm not sure why it would have been removed.
04 Sep 2022 06:49 #251156
the code has been commented out in 2.8 as well.
04 Sep 2022 17:32 #251176
by CNC_Tux
Hello cmorley,
thank you so much for the information.
what is to do, to works with optional blocks ?
It is a special order in G-Code?
04 Sep 2022 20:33 #251180
took me a bit to find it:
linuxcnc.org/docs/stable/html/gcode/overview.html#_block_delete
04 Sep 2022 20:34 #251181
Sorry maybe I miss understood.
Are you asking how to get optional stop to work in GMoccapy?
05 Sep 2022 07:33 #251213
by CNC_Tux
Hello cmorley,
yes that was my question .... but i read the block delete, if i understand right, i can do close to the same action.
as sample:
/ M1
would like be the same like the optional stop?
Right?
as sample:
/ M1
Right?
05 Sep 2022 10:08 #251221
by CNC_Tux
Hello cmorley,
thank you so much, the sample is working.
The Function "Block delete" have much more possibilities and the optional stop is working too
"/ M1" or "/ M0" is working too.
its really not so bad this function
Cheers
Reinhard
Cheers
Reinhard
Time to create page: 0.590 seconds
