Gmoccapy doesn't start. Reference button?
07 Sep 2022 17:28 #251424
by chili023
Gmoccapy doesn't start. Reference button? was created by chili023
Hi
I am setting up a new machine. A simple XYZ Router. No encoders with step/dir on an 7i76ED.
Axis starts but when gmoccapy tries to construct the homing buttons it fails.Found an error!
Error message:
The following information may be useful in troubleshooting:
File "/usr/bin/gmoccapy", line 5237, in <module>
app = gmoccapy(sys.argv)
File "/usr/bin/gmoccapy", line 269, in __init__
self._make_ref_axis_button()
File "/usr/bin/gmoccapy", line 664, in _make_ref_axis_button
btn.set_property("tooltip-text", _("Press to home {0} {1}").format(name_prefix_sg, elem.upper()))
AttributeError: 'int' object has no attribute 'upper'
upper() in python means convert to Upper Case as I understand.
Never encountered such a problem.
I used the latest ISO for the installation and I am running 2.8.3.
Thanks Andreas
Error message:
Thanks Andreas
08 Sep 2022 10:10 #251476
by HansU
Replied by HansU on topic Gmoccapy doesn't start. Reference button?
This error recently popped up but it was unfortunately only fixed in master (LinuxCNC 2.9): github.com/LinuxCNC/linuxcnc/pull/1842
I pushed a fix to 2.8.
The following user(s) said Thank You: chili023
Time to create page: 0.061 seconds
