tool change incompatibility
02 Oct 2022 10:53 #253241
by furynick
tool change incompatibility was created by furynick
I recently swiched to gmoccapy and I'm not able to load programs with tool change.
This line was in my ini file since a long time ago and works without issue with axis :NGC file is attached
Using gmoccapy, when I load a file with a Txx M6 I get following error :
REMAP=M6 modalgroup=6 ngc=tool_change
G-Code error in mill.ngc
Near line 0 of
/home/cnc/linuxcnc/nc_files/mill.ngc
M7x: restore_settings failed executing: ' F0,0': Bad character ',' used
- Online
- Thank you received: 5943
25 Oct 2022 00:03 #254976
Replied by tommylight on topic tool change incompatibility
Found this in the deleted stuff, i can not find a reason for it being deleted, so i restored it.
Please let me know if it should be removed.
Thank you.
Thank you.
25 Oct 2022 12:28 #255024
This looks like a locale problem. F0,0 is invalid G-code, it should be F0.0
(it's in the mill.ngc file, not the toolchange.ngc file)
Replied by andypugh on topic tool change incompatibility
