run from line
27 Jan 2023 09:02 #262994
by MichalHK
run from line was created by MichalHK
Hello,
please how is correct rules for using this function?
In settings I have run from line enabled.
I simple select row 14, but program runs from begining.
If I run program from begining and pause it button run from line is not allowed.
Using gmoccapy 3.0.9.1. I now ist old. But I hope this feature in this version works good.
Thanks Michal
Thanks Michal
- Thank you received: 5944
27 Jan 2023 12:20 #262997
Replied by tommylight on topic run from line
In Axis, left click on line, right click and select "run from line" from the menu.
27 Jan 2023 18:07 #263017
by HansU
Replied by HansU on topic run from line
11 Feb 2023 18:29 - 11 Feb 2023 18:30 #264301
by MichalHK
Replied by MichalHK on topic run from line
Hmm my machine is bad of course
I tested it today.
For example
Program using tool number 1, 2, 3.
I stop program at tool 2. Revind program at the top. Then click to run from line enter row number with T02M6 and start.
Insteed of program continuing with tool 2. Machine start to change into tool 1.
I tested it today.
For example
Last edit: 11 Feb 2023 18:30 by MichalHK.
Time to create page: 0.158 seconds
