Auto Tool Measurement setup,issues
- Kasper-001
- Topic Author
- Thank you received: 5
29 Apr 2023 19:25 #270227
by Kasper-001
Auto Tool Measurement setup,issues was created by Kasper-001
hello
im trying to setup auto tool measurement
i was following this guide linuxcnc.org/docs/html/gui/gmoccapy.html...uto-tool-measurement
now i get this error
Debug file information:
custom_postgui.hal:11: Pin 'gmoccapy.toolchange-change' does not exist
i can´t find out where to put that pin
attached my config folder
29 Apr 2023 19:44 #270229
by zz912
Replied by zz912 on topic Auto Tool Measurement setup,issues
What version of LinuxCNC do you use?
Do you see the pin gmoccapy.toolchange-change in halshow?
Could you add here whole Debug file ?
- Kasper-001
- Topic Author
30 Apr 2023 05:52 - 30 Apr 2023 05:58 #270292
by Kasper-001
Replied by Kasper-001 on topic Auto Tool Measurement setup,issues
2,8
yes i see the pin gmoccapy.toolchange-change in halshow im my stable verison, before the auto tool measurement setup.
here is the full report :
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2-11-g6a3d0a434
Machine configuration directory is '/home/cnc/linuxcnc/configs/test2.11'
Machine configuration file is 'test2.11.ini'
INIFILE=/home/cnc/linuxcnc/configs/test2.11/test2.11.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ kinstype=BOTH
Starting LinuxCNC...
Found file(REL): ./test2.11.hal
Running HAL shutdown script
2232
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: lør 29 apr 20:29:49 CEST 2023
UTC Date: lør 29 apr 18:29:49 UTC 2023
this program: /usr/bin/linuxcnc_info
uptime: 20:29:49 up 37 min, 1 user, load average: 3,39, 3,16, 2,95
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/cnc/linuxcnc/configs/test2.11
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/cnc/linuxcnc/configs/test2.11/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.194-3 (2021-07-18)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-17-rt-amd64 root=UUID=bb3f090a-774e-4c67-aadf-218301a19008 ro initrd=/install/gtk/initrd.gz quiet
model name: Intel(R) Core(TM) i5-4400E CPU @ 2.70GHz
cores: 2
cpu MHz: 1299.639
parport:
serial: 0000-0000 : serial 0000-0000 : serial 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.2-11-g6a3d0a434
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Ønsket=Ukendt/Installér/(R)fjern/(P)udrens/tilbageHold
| Status=(N)ikke/Installeret/(C)Konfigfiler/Udpakket/(F)halvkonfig./
|/ Halvt-installeret/(W)afventer-udløser/(T)udløser-afventer
|| Fejl?=(ingen)/tilbilbageHoldt/geninstallation-kRæves/X=begge-problemer
|| / (Status, Fejl: store bogstaver=alvorligt)
||/ Navn Version Arkitektur Beskrivelse
un linuxcnc <ingen> <ingen> (ingen tilgængelig beskrivelse)
un linuxcnc-dev <ingen> <ingen> (ingen tilgængelig beskrivelse)
un linuxcnc-doc <ingen> <ingen> (ingen tilgængelig beskrivelse)
ii linuxcnc-doc-en 1:2.8.2.11.g6a3d0a434 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.2.11.g6a3d0a434 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.8.2.11.g6a3d0a434 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <ingen> <ingen> (ingen tilgængelig beskrivelse)
un linuxcnc-sim-dev <ingen> <ingen> (ingen tilgængelig beskrivelse)
ii linuxcnc-uspace 1:2.8.2.11.g6a3d0a434 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.2.11.g6a3d0a434 amd64 PC based motion controller for real-time Linux
Last edit: 30 Apr 2023 05:58 by Kasper-001.
05 May 2023 04:57 #270694
by newbynobi
Replied by newbynobi on topic Auto Tool Measurement setup,issues
May be the order to load stuff in your postgui Hal files may cause that.
Post INI and Hal file.
Norbert
Norbert
