MAcro buttons in MDI will not show
03 May 2023 13:31 - 03 May 2023 14:01 #270566
by CNCGOOS
Replied by CNCGOOS on topic MAcro buttons in MDI will not show
one other question about parameters and Macro's
i have made the next ngc file
when i Start the MACRO everything went well. so I can give the 7 parameters.
and when the maco is executed there is a error about the lst parameter what is decelerd.
error is following #<spindel> not decelard
Last edit: 03 May 2023 14:01 by CNCGOOS.
03 May 2023 16:30 #270578
by HansU
Replied by HansU on topic MAcro buttons in MDI will not show
No idea actually.
But if you use macros with such a lot of parameters I suggest using NGCGUI. It's just an input mask for ngc files. See here
linuxcnc.org/docs/2.9/html/gui/ngcgui.html
But especially here: linuxcnc.org/docs/2.9/html/gui/ngcgui.ht...cp_tab_page_in_a_gui
But however this sound more like a G-code problem, so maybe it fits better here: forum.linuxcnc.org/40-subroutines-and-ngcgui
04 May 2023 19:24 #270665
by CNCGOOS
Problem solved
Parameter decalration to namde parameters moved inside de macro sub
Time to create page: 0.120 seconds
