Lathe wear problem
16 Jul 2023 22:03 #275598
by MaxEkb77
Lathe wear problem was created by MaxEkb77
Hello, try to use lathe wear & got error when edit
File "/usr/lib/python3/dist-packages/gladevcp/tooledit_widget.py", line 458, in col_editted
(store_path,) = self.tool_filter.convert_path_to_child_path(path)
TypeError: argument filter_path: Expected Gtk.TreePath, but got str
03 Aug 2023 15:03 #276837
by HansU
Replied by HansU on topic Lathe wear problem
Can you give us some more information how to reproduce this error?
17 Aug 2023 17:52 #278287
by MaxEkb77
Replied by MaxEkb77 on topic Lathe wear problem
install lathe gmoccapy sim
add lathe_wear_offset ini ini
try edit tool in wear window& got error
18 Aug 2023 01:46 #278319
by JPL
Replied by JPL on topic Lathe wear problem
At a bare minimum we will probably need the linuxcnc and debian version too...install lathe gmoccapy sim
18 Aug 2023 05:29 #278324
by MaxEkb77
on my virtual machine now bookworm & linuxcnc 2.9 .
on buster same i see same problem.
Time to create page: 0.142 seconds
