Smaller hbox_jog [SOLVED]
01 Aug 2023 15:24 - 03 Aug 2023 18:51 #276704
by zz912
Smaller hbox_jog [SOLVED] was created by zz912
Last edit: 03 Aug 2023 18:51 by zz912.
01 Aug 2023 18:24 #276719
by spumco
Replied by spumco on topic Smaller hbox_jog
I don't know how to accomplish what you want, but I think that box (#2) is shared with the g-code and MDI displays while in Auto/MDI modes.
If you squeeze down box #2 to get rid of the HMI jog controls you'll not have much real estate to see more than a couple lines of gcode. You OK with it like that?
The following user(s) said Thank You: zz912
01 Aug 2023 19:17 #276724
by zz912
Replied by zz912 on topic Smaller hbox_jog
01 Aug 2023 19:39 #276726
by spumco
Not sure if you are aware, but you can change the DRO character/font size in the gmoccapy settings page. Try increasing to 50 or so and see if that helps out.
I've also found that some of the windows/boxes are size-adjustable simply by hovering and dragging the edge of the windows.
01 Aug 2023 19:47 #276728
by zz912
If I increase the DRO, the horizontal buttons disappear.
01 Aug 2023 20:05 - 02 Aug 2023 06:57 #276732
by HansU
Replied by HansU on topic Smaller hbox_jog
I think this does what you want. It hides the jog buttons but keeps the slider for the jog rate. The documentation is a bit unprecise at this point, I must admit.
EMBED_TAB_NAME = some_name
EMBED_TAB_LOCATION = hbox_jog
EMBED_TAB_COMMAND = hide
Last edit: 02 Aug 2023 06:57 by HansU.
01 Aug 2023 20:21 #276735
by spumco
You mean the bottom row buttons? Not good.
I hope someone else more familiar with gmoccapy can chime in 'cause I'm out of ideas on how to modify the screen to get you a bigger DRO.
Maybe there's a way to get rid of the spindle on/off buttons in box #6 to make it smaller. Sounds like you want physical buttons for jogging - maybe for spindle control too? If those huge spindle buttons were gone, that'd get you a fair bit of room to shift everything around and get a larger DRO.
- Thank you received: 5951
01 Aug 2023 20:58 #276740
Replied by tommylight on topic Smaller hbox_jog
Who deleted Hansu's post?
I restored it, let me know if it needs deleting.
Thank you.
Thank you.
02 Aug 2023 06:59 #276763
by HansU
It was me . I wanted to wait until I can test it to give a more certain answer Sorry for the confusion. I have updated the post now.
Thank you.
02 Aug 2023 11:25 #276774
No worries, just making sure.
Since most of us who check here often are on mobile phones, plenty of space ... hmmm for mistakes.
Maybe plenty was not the right word
Time to create page: 0.275 seconds
