Smaller hbox_jog [SOLVED]
02 Aug 2023 13:44 #276778
by HansU
Replied by HansU on topic Smaller hbox_jog
Yeah I know that
@zz912
But if you want to hide something that is not available as an embedded tab, you have to first locate the widget using the glade editor like described here: linuxcnc.org/docs/2.9/html/gui/gladevcp....a_new_user_interface
And then just create a user command file with the line
self.widgets.<widget-name>.hide()
self.widgets.hbox_jog.hide()
for your case.
Another solution for you could also be to remove or reduce the number of step buttons in your ini file (display section).
@zz912
for your case.
03 Aug 2023 15:00 - 03 Aug 2023 15:01 #276836
by HansU
Removing does not work, but you can reduce it to one or two buttons like this
INCREMENTS = 1.000
or this:
INCREMENTS = 1.000 mm, 0.100 mm
INCREMENTS = 1.000
or this:
Last edit: 03 Aug 2023 15:01 by HansU.
The following user(s) said Thank You: zz912
03 Aug 2023 18:50 #276841
by zz912
Replied by zz912 on topic Smaller hbox_jog
This solved my problem. Thank you.I think this does what you want. It hides the jog buttons but keeps the slider for the jog rate. The documentation is a bit unprecise at this point, I must admit.
EMBED_TAB_NAME = some_name EMBED_TAB_LOCATION = hbox_jog EMBED_TAB_COMMAND = hide
Time to create page: 0.163 seconds
