M6 REMAP ERROR
- marco@cheli.info
29 Aug 2023 12:31 #279277
by marco@cheli.info
M6 REMAP ERROR was created by marco@cheli.info
HiI'm trying to get my first three axis machine to work. I'm not able to understand why during auto tool
measurement (chapter 4.2.6) I receive this error message:
pycall(remap.change_prolog)failed
Seems to related to REMAP=M6 instance but I'm outing crazy because I don't find the way to solve the issue.
The problem maybe in the stdglue.py file copied from /usr/share/doc/linuxcnc/examples/sample-configs/sim/gmoccapy of the iso linuxcnc-2.7.14-wheezy.iso image
Please can someone help me?
Thanks for the attention
marco c.
marco c.
29 Aug 2023 12:56 - 29 Aug 2023 12:58 #279280
Replied by Aciera on topic M6 REMAP ERROR
Make sure that all .py files are marked as executable.
Right click on the file -> Properties -> permissions (or something similar)
[edit]
Just to be clear, are you actually working with inuxcnc-2.7.14-wheezy or is that only where the file came from?
[edit]
Last edit: 29 Aug 2023 12:58 by Aciera.
- marco@cheli.info
29 Aug 2023 13:38 #279282
by marco@cheli.info
Replied by marco@cheli.info on topic M6 REMAP ERROR
Thanks for your reply
Yes all files in python folder are executable (now) but the problem persists
I'm using linuxcnc 2.7.15, there was an automatic update after first startup
marco
marco
29 Aug 2023 13:51 #279284
can you please post your ini file?
- marco@cheli.info
29 Aug 2023 14:03 #279286
by marco@cheli.info
Hereafter
thanks
# Generated by stepconf 1.1 at Sat Aug 19 10:43:20 2023
# overwritten when you run stepconf again
[EMC]
MACHINE = FRESA
DEBUG = 0
[DISPLAY]
DISPLAY = gmoccapy
PREFERENCE_FILE_PATH = gmoaccapy_preferences
DEFAULT_LINEAR_VELOCITY =166.666
MAX_LINEAR_VELOCITY = 166.666
MAX_FEED_OVERRIDE = 1.5
MAC_SPINDLE_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
PROGRAM_PREFIX = /home/pi/linuxcnc/nc_files
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 2.50
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 25.00
INTRO_TIME = 5
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = macros
FEATURES=12
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
[PYTHON]
PATH_PREPEND = python
TOPTRAVEL = python/toplevel.py
[TOOLSENSOR]
X = 85
Y = 180
Z = 140
MAXPROBE = -20
[CHANGE_POSITION]
X = 180
Y = 180
Z = 180
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = FRESA.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.50
MAX_VELOCITY = 25.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 195.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXACCEL = 937.5
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 200.0
HOME_OFFSET = 199.000000
HOME_SEARCH_VEL = 20.000000
HOME_LATCH_VEL = 6.250000
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_1]
TYPE = LINEAR
HOME = 195.0
MAX_VELOCITY = 25.0
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 200.0
HOME_SEQUENCE = 2
[AXIS_2]
TYPE = LINEAR
HOME = 195.0
MAX_VELOCITY = 25.0
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 200.0
HOME_SEQUENCE = 0
thanks
[EMC]
MACHINE = FRESA
DEBUG = 0
[DISPLAY]
DISPLAY = gmoccapy
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
FEATURES=12
[PYTHON]
[TOOLSENSOR]
X = 85
Y = 180
Z = 140
MAXPROBE = -20
[CHANGE_POSITION]
X = 180
Y = 180
Z = 180
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
HALFILE = FRESA.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 195.0
MAX_VELOCITY = 25.0
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 200.0
HOME_SEQUENCE = 1
[AXIS_1]
TYPE = LINEAR
HOME = 195.0
MAX_VELOCITY = 25.0
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 200.0
HOME_SEQUENCE = 2
[AXIS_2]
TYPE = LINEAR
HOME = 195.0
MAX_VELOCITY = 25.0
SCALE = 80.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 200.0
HOME_SEQUENCE = 0
29 Aug 2023 14:15 #279288
You have a typo in the [PYTHON] section of your ini. Try changing:
to
TOPLEVEL = python/toplevel.py
to
- marco@cheli.info
29 Aug 2023 14:32 #279289
by marco@cheli.info
I'm really stupid...
sorry
something is changed but may be present some other stupid think I made...
linuxcnc starts but gmoccapy doesn't appare....
thanks
sorry
thanks
- marco@cheli.info
29 Aug 2023 14:35 #279290
by marco@cheli.info
Sorry ...
Now seems to be all OK
thanks
thanks
29 Aug 2023 14:37 #279291
No problem, glad you got it working.
The following user(s) said Thank You: tommylight, zz912
Time to create page: 0.226 seconds
