Hot plug of USB drives
18 Sep 2023 09:18 #281057
by mariusl
Regards
Marius
www.bluearccnc.com
Hot plug of USB drives was created by mariusl
I am trying to get Gmoccapy to pick up the USB drive if it is hot plugged. I have set the PROGRAM_PREFIX = /media/router.
It would seem that the program only looks at that location during startup and never again. So if I plug the USB drive in after startup the drive is not located. Am I correct in assuming that this is not possible in Gmoccapy?
It is used in other programs like QTPlasmaC so it should be possible.
Does anyone know how to achieve this?
I am using Gmoccapy 3.4.3 on master
Regards
Marius
www.bluearccnc.com
18 Sep 2023 09:33 #281059
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Hot plug of USB drives
It seems that I have to wait a bit longer for the mount to happen. It seems to take a long time to mount though.
Regards
Marius
www.bluearccnc.com
- Thank you received: 5951
18 Sep 2023 14:31 #281080
Replied by tommylight on topic Hot plug of USB drives
What OS? Debian?
USB mounting is Linux duty, GmoccaPy can not do anything about it.
Try different USB sticks if you can, some mount quite fast, some take ages, usually depends on the speed and access time of the stick more than speed of the PC.
18 Sep 2023 15:07 #281087
by mariusl
Regards
Marius
www.bluearccnc.com
Thanks for the reply Tommy
Using Debian Buster. I got linux to mount them but the speed was bad. I will try another stick. I was probably just to impatient.
Regards
Marius
www.bluearccnc.com
18 Sep 2023 15:16 #281091
Another thing, if using extension cable, try to find a better quality one, makes a huge difference.
From experience, i have over 200 USB cables around here and in the shops, most are useless, but i did not know that for sure until i got a USB tester a month ago, now it's probably down to 60 or 70 cables, the rest got binned!
It hurts to think how many times those have caused me grief. The strange thing is, some cheap ones turned out quite good and some expensive ones had to go.
Cheap, but good:
Ugreen
Baseus
Anker
Avoid other cheap ones.
Cheap, but good:
Ugreen
Baseus
Anker
The following user(s) said Thank You: mariusl
Time to create page: 0.281 seconds
