Hot keys Gmoccapy
- manager12345
07 Nov 2023 09:44 - 07 Nov 2023 09:45 #284761
by manager12345
Hot keys Gmoccapy was created by manager12345
Hello everyone I want to add keyboard shortcuts to Gmoccapy. I found a solution without getting into the code gmoccapy.py using hal_input, but when I load the code for the hotkeys, gmoccapy throws an error.
I am using gmoccapy in stepconfig simulation mode. Please tell me how to implement this correctly so that everything starts correctly.
Last edit: 07 Nov 2023 09:45 by manager12345.
20 Nov 2023 11:15 #286018
Replied by andypugh on topic Hot keys Gmoccapy
It looks like the problem is with hal_input, have you set the udev_rules?
Are you confident that the identifier string for the device is correct?
You may need to add your user account to a suitable group.
linuxcnc.org/docs/stable/html/man/man1/h...ISSIONS%20AND%20UDEV
- manager12345
21 Nov 2023 10:41 #286157
by manager12345
Replied by manager12345 on topic Hot keys Gmoccapy
Yes, I did. And it worked! Thank you for the answer!
11 Jan 2024 13:49 #290425
by HansU
Replied by HansU on topic Hot keys Gmoccapy
Can you describe in detail how resolved it? Thanks!
