making changes to LinuxCNC files
- manager12345
07 Nov 2023 17:23 #284803
by manager12345
making changes to LinuxCNC files was created by manager12345
Hello everyone I decided to make hotkeys and got into the code gmoccapy.py , and also decided to add my custom icons for different tasks. But that hotkeys and icons do not appear in the gmoccapy program. Changed the MDI hotkey to F4, instead of F5. Please tell me how I can make gmoccapy see that I have made changes to the code and icons
- Online
- Thank you received: 5952
07 Nov 2023 17:24 #284804
Replied by tommylight on topic making changes to LinuxCNC files
Moved to "GmoccaPy" section.
07 Nov 2023 17:31 #284805
Replied by Aciera on topic making changes to LinuxCNC files
If you built linuxcnc yourself then you would want to modify '<your-linuxcnc-install-folder>/bin/gmoccapy.py' (ie not the one that lives in the folder /src/emc/usr_intf/gmoccapy/)
I don't know where things get installed on a deb installation.
07 Nov 2023 19:56 #284816
by HansU
Replied by HansU on topic making changes to LinuxCNC files
Edit the file /bin/gmoccapy
- manager12345
08 Nov 2023 04:21 #284837
by manager12345
Replied by manager12345 on topic making changes to LinuxCNC files
I changed the file both in /bin/gmoccapy and in /user_intf/gmoccapy, but still nothing has changed, the program operates according to the old code, creating a new gmoccapy configuration… I'm already thinking about the option to build my LinuxCNC, with the changes in the files that I need, do you think there will be a good option or can I somehow bypass all this and just install changes in these files?
08 Nov 2023 14:54 #284872
by HansU
You can modify the sources and build LinuxCNC and then install this.
More information here: linuxcnc.org/docs/html/code/building-linuxcnc.html
But shouldn't be necessary in your case. I have no idea why editing /bin/gmoccapy doesn't work for you.
- manager12345
08 Nov 2023 15:55 #284877
by manager12345
And this can't be due to the fact that I have Debian 12 and LinuxCNC is rolled on it?
Most likely, I will do according to your advice and will assemble my assembly and install LinuxCNC.
27 Nov 2023 13:37 #286618
by HansU
If your changes in the gmoccapy files show no effect - maybe your changes are at the wrong location or just wrong?
You could post your modified file and tell us what it is supposed to do.
Time to create page: 0.158 seconds
