Tool table with wear
13 Dec 2023 10:29 #288012
by dinkata
Tool table with wear was created by dinkata
Hello,
my lathe configuratin Mesa 5i25 + 7i77 . Linuxcnc 2.9.1 with Gmoccapy.
Is there a table of tools with wear !
Thanks !
Thanks !
13 Dec 2023 18:52 #288062
by HansU
Replied by HansU on topic Tool table with wear
As far as I know this is not supported in gmoccapy.
14 Dec 2023 05:51 #288100
Replied by cmorley on topic Tool table with wear
The display of tool offsets in the offsets page for lathes should work (tools numbers above 10000 are assumed wear settings.)
But i haven't tried it recently.
But linuxcnc needs to use remap code to use the wear offsets.
14 Dec 2023 06:04 #288101
add:
LATHE_WEAR_OFFSETS = 1
to the INI file, under [DISPLAY]
The following user(s) said Thank You: dinkata
15 Dec 2023 11:11 - 15 Dec 2023 11:13 #288212
by virencq
Replied by virencq on topic Tool table with wear
Hi, Place in .ini file under [DISPLAY] section:
LATHE = 1
BACK_TOOL_LATHE = 0
rename attached file to tool.tbl
LATHE = 1
BACK_TOOL_LATHE = 0
Last edit: 15 Dec 2023 11:13 by virencq.
Time to create page: 0.144 seconds
