Gmoccapy audio error on tool change
15 Jan 2024 10:49 #290750
by mariusl
Regards
Marius
www.bluearccnc.com
Gmoccapy audio error on tool change was created by mariusl
I am running 2.9.2 on Debian Bullseye. Updated now.
In Gmoccapy I turned the Sound option to off and confirmed that the .prefs file also has the audio as false.
When I do a tool change there is an error form Gmoccapy on line 5414 object has no attribute ' audio_active'.
I assume this to be a bug as the sound option is turned off but this function does not have an attribute to turn the audio off. Other dialogs have the option.
Regards
Marius
www.bluearccnc.com
15 Jan 2024 12:59 #290755
by HansU
Replied by HansU on topic Gmoccapy audio error on tool change
This fix missed the 2.9.2 release by 8 days. It's just one line, you can add it manually or you can install the deb from the build bot (I would recommend the latter, I have done several fixes for gmoccapy after the 2.9.2 release):
github.com/LinuxCNC/linuxcnc/commit/760f...de07ea08b3f00b09b57f
15 Jan 2024 17:13 - 15 Jan 2024 17:43 #290772
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy audio error on tool change
I have just taken the machine of the buildbot master as there are other issues.
I will do the manual fix for now.
What are the other fixes? anything that is critical?
Regards
Marius
www.bluearccnc.com
Last edit: 15 Jan 2024 17:43 by mariusl.
16 Jan 2024 08:52 #290842
by HansU
All what is listed after 3.4.6: linuxcnc.org/docs/html/gui/gmoccapy_release_notes.txt
Maybe this one could hit you, if you are running on 1024x768 "Fixed increasing of window size when clicking edit button"
16 Jan 2024 10:06 #290852
by mariusl
Regards
Marius
www.bluearccnc.com
The machine has a hi resolution touch screen so this should be fine. I did the fix already and unless there are any other problems I will wait for the next release before I update that machine.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.126 seconds
