Missing py
- tcoleman978
23 Jan 2024 21:15 #291468
by tcoleman978
Missing py was created by tcoleman978
I have modified the gmoccapy.py file so the lathe DRO's behave like I want for Dia programming.
As of this last update this piece of py went missing. I can not find "gmoccapy.py" anywhere on the Rpi4B.
.....But things still work, just not how I want(back to stock).
What happened? I'm having enough trouble sorting out what is Linuxcnc problems and what are Linux problems. Now this.
Has how this is all implemented changed?
Help please.
Help please.
23 Jan 2024 21:46 #291471
by HansU
Replied by HansU on topic Missing py
Did you update from 2.9.1 to 2.9.2?
However, a better approach would be to do your changes in the user command file, a feature which was introduced in Gmoccapy up from LinuxCNC 2.9: linuxcnc.org/docs/html/gui/gmoccapy.html#_user_command_file
This allows you to do your adaptions that will not been overwritten by updates.
- tcoleman978
24 Jan 2024 00:03 #291478
by tcoleman978
Replied by tcoleman978 on topic Missing py
1) A week or so ago,The little box said update?... I said sure....grrr.
2) As I understand the function is for static changes. Like color, icon, ect.
what I did was a logic mod to make the DRO "disappear" by making all objects in the DRO box the same version of black also I called the Dia display X. As the G7/G8 is called the displays are blanked or shown.
- tcoleman978
26 Jan 2024 18:55 #291675
by tcoleman978
Finally back to it and found it. Looks like 2.9.2
Time to create page: 0.153 seconds
