tutorial for Gmoccapy migration from axis ?
- smc.collins
- Thank you received: 109
25 Mar 2024 23:17 #296781
by smc.collins
tutorial for Gmoccapy migration from axis ? was created by smc.collins
searched but came up empty, the google foo may just be weak today. Looking for a good tutorial on migrating to Gmoccapy
- Thank you received: 5944
25 Mar 2024 23:44 #296786
Replied by tommylight on topic tutorial for Gmoccapy migration from axis ?
Back in the times, all that was required to change was editing the ini file, display section, replace display = axis with display = gmoccapy
26 Mar 2024 14:59 #296820
by zz912
Replied by zz912 on topic tutorial for Gmoccapy migration from axis ?
I can recomend make new configuration with PNCconf.
30 Mar 2024 19:45 #297229
by HansU
Still the case for a standard configuration.
For example if you change in the axis_mm sample config
DISPLAY = axis to DISPLAY = gmoccapy, it will work.
But if you have a configuration that uses some of the axis-specific pins like axisui.XXX, it wouldn't be that simple.
And there are gmoccapy-specific pins as well that improves the usability. So recommend to use.
Replied by HansU on topic tutorial for Gmoccapy migration from axis ?
