Gmocappy has bad respons in front end
02 Apr 2024 20:02 - 02 Apr 2024 20:04 #297456
by CNCGOOS
Gmocappy has bad respons in front end was created by CNCGOOS
Hello all,
LCNC was al long time wel working. Last week starts bad bij not starting up Gmocappy.
Setup: Linuxcnc 2.9.2
Bookworm 12 ISO i have instaled
Gmocappy latest version
I have yesterday run the update commando's to see if that solves the problem. but unfortanely no sucses.
When is start LCNC wij Classic ladder works oke
some times some buttons work with a Large Delay.
I see also not the preloaded G codes left in the screen
dos annyone have e suggestion where /how i have to fix this problem
Last edit: 02 Apr 2024 20:04 by CNCGOOS.
- Thank you received: 5944
02 Apr 2024 20:18 #297458
Editing Linux files on a windows PC is never a good idea.In BIOS, disable hyperthreading, power saving options, TPM, virtualisation, etc, as this will cause issues during work.Those entries are missing from the ini file, although this is not the issue for now, these have to be set properly.
Replied by tommylight on topic Gmocappy has bad respons in front end
./spindle.hal:4: Warning: File contains DOS-style line endings.
Unexpected realtime delay on task 0 with period 1000000
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
03 Apr 2024 08:06 #297492
by CNCGOOS
Replied by CNCGOOS on topic Gmocappy has bad respons in front end
Thanks voor the tips.
I will tinight try the channges.
About the windows/dos editor yes i know but in house is it bether near the Stove.
the other warnings i wel add to the Ini File
Time to create page: 0.169 seconds
