Configuring ATC
- mswierczek19
- Banned
27 May 2020 15:38 - 27 May 2020 15:39 #169134
by mswierczek19
Configuring ATC was created by mswierczek19
I have a problem with configuration for automatic toolchanger.
My lathe is modification from conventional lathe to cnc controlled machine.
I have a revolver turret with no locking system its based on strain wave gearing and servomotor.
The servomotor is defined as A axis in Milling mode, so g-codes like G0 and G1 is working perfectly, but i would like to make use of M6 code, because it must work with offsets for each tool separately. I have no skill in programming scripts, so i cant make it by myself and i need your help with it.
Is there any complete script for that kind of ATC or similar turret?
Would that work in lathe mode in LinuxCNC (this mode uses only 2 axis, but A axis would be possible to use ONLY in Milling mode)?
Do you have any ideas for that?
I think there is simple solution, but i cant go forward with work in cycle process without it, and i need it ASAP.
im attaching in configurations of my lathe:
1. Frezarka- Milling mode (Y axis have no use there, i need to remove it cause it makes bugs and troubles sometimes, even the programs stops)
2. Tokarka- Lathe mode (without A axis)
Last edit: 27 May 2020 15:39 by mswierczek19.
- Thank you received: 5944
27 May 2020 15:50 #169136
Replied by tommylight on topic Configuring ATC
Have a look at this, see if you can use it
linuxcnc.org/docs/2.8/html/man/man9/carousel.9.html
27 May 2020 18:55 #169143
by Henk
Replied by Henk on topic Configuring ATC
I think you can just add an axis by manually editing your lathe config. Basically copy the axis sections from your milling config and edit the ini file. See
Link
Regarding control of the changer, I think the best way is to remap m6 and then use gcode to move the a axis to the correct tool position.
Remap basically disables the standard m6 actions and allows you to "intercept" the m6 process and to run your own subroutine (gcode) to perform the toolchange. Check the docs for details
- mswierczek19
- Banned
30 May 2020 11:25 #169413
by mswierczek19
Replied by mswierczek19 on topic Configuring ATC
will the offset for each tool then work?
can you describe this solution step by step how to do it? I have not much skill in programming and setting on linuxCNC, and i don't want to do somethink wrong and break my lathe.
30 May 2020 12:09 #169417
probably not without you giving us much more info on how the turret is set up, how it is driven and what pins/switches it uses.can you describe this solution step by step how to do it?
- mswierczek19
- Banned
30 May 2020 15:51 #169425
by mswierczek19
I attached Config files, you can download and read all configurations of my system. Turret has no locks, its just servo and strain wave gearing
30 May 2020 16:02 #169428
Configs are missing, and does the turret have any switches/sensors ?
30 May 2020 16:07 #169429
by Henk
Read the m6 part of this. linuxcnc.org/docs/html/remap/remap.html
It seems intimidating but it is not that difficult.
- mswierczek19
- Banned
02 Jun 2020 18:40 #169857
by mswierczek19
this is config files:
The following user(s) said Thank You: Фрезер
Time to create page: 0.106 seconds
