NativeCAM is Features renamed
08 Oct 2016 21:41 #81434
by FernV
How are you using it then ? Are you using drilling modes G73, 81, 82 or 83 ?
One option is using a Drill Change and not activate, this will not ask for a tool change but set the feed, speed and mode but you have to use the drilling subroutines
What is your p.o.v. on this ?
I think I can solve this
Fern
Replied by FernV on topic NativeCAM is Features renamed
I use very often end mills for drilling opperations, as it allows saving tool changes.
if you are in metric and you enter a user defined drill diameter, lets say 4.2 mm, it will be interpretet as inch value.
Fern
The following user(s) said Thank You: newbynobi
08 Oct 2016 21:58 #81436
by FernV
Corrected and on github
- kramdradoow
09 Oct 2016 02:02 #81442
by kramdradoow
Replied by kramdradoow on topic NativeCAM is Features renamed
Thanks for the new release Fern.
I finished loading a new system with the most recent live cd and applied all updates. I successfully loaded that python thing. I downloaded your latest release an hour or so ago and extracted it to my home dir. I found that extracting it to /mark resulted in dir structure of /NativeCAM-master/NativeCAM-master/then_all_of_your_files.
The only thing in the first NativeCAM-master directory was the subdirectory NativeCAM-master with its sub directories and files. So I renamed the directory structure, moved the files and deleted redundant subdirectory. So now my structure matches what you show in your mill.ini file /mark/ncam/then_all_of_your_files.
Not sure what significance this has but I was able to load the embedded version into axis sim.
Thought I would provide a status report of my findings.
Mark
Mark
09 Oct 2016 03:15 #81443
by FernV
Hi Mark,
Sounds like you downloaded a zip file, isn't it ?
Next time, try to clone. In a terminal in the directory of your choice
copy this command : git clone github.com/FernV/NativeCAM.git
Updates will be much simpler
Fern
Fern
09 Oct 2016 03:18 #81444
by gmouer
I assume that command gets pasted into a terminal window? I tried it and got the following error.
george@toshiba:~$ git clone github.com/FernV/NativeCAM.git
fatal: repository 'github.com/FernV/NativeCAM.git' does not exist
george@toshiba:~$
Replied by gmouer on topic NativeCAM is Features renamed
Hi Mark,
Fern
george@toshiba:~$
09 Oct 2016 09:00 #81447
by dinkata
Replied by dinkata on topic NativeCAM is Features renamed
FernV
Congratulations on a good job !
It will be good to have a lathe .
09 Oct 2016 09:28 #81448
by FernV
Sorry, I did not double check
It appears the the leading "https://" before "github" was removed when I posted
You can copy the address from the green button on that github site but do not forget the
"git clone "
In fact, you can use your home directory ~/
A sub-directory NativeCAM will be created and the whole process takes seconds
To have the latest updates you change directory to NativeCAM and issue :
git pull origin master
and do it anytime
If someone knows a better command to update, please correct
Fern
"git clone "
and do it anytime
Fern
- eFalegname
- Thank you received: 30
09 Oct 2016 09:47 - 09 Oct 2016 09:52 #81450
by eFalegname
Replied by eFalegname on topic NativeCAM is Features renamed
Hi Fern I'm very excited with your great work, thank you very much.
I cloned the last version and try to install it, this is the error I get on Linuxmint 17.3 Xfce-64bit:
then I did:
and the problem persists; it's seems I'm doing something wrong, please help
ef@pl ~/linuxcnc/configs/NativeCAM $ sudo python setup.py
File "setup.py", line 54, in <module>
os.symlink(os.path.join(os.getcwd(), 'ncam.py'), fn)
OSError: [Errno 17] File exists
then I did:
ef@pl ~/linuxcnc/configs/NativeCAM $ sudo python setup.py c
"from ncam import NCam" removed from /usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py
glade-widget-class named NCam removed from /usr/share/glade3/catalogs/hal_python.xml
glade-widget-class-ref name NCam removed from /usr/share/glade3/catalogs/hal_python.xml
"from ncam import NCam" added to /usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py
Last edit: 09 Oct 2016 09:52 by eFalegname.
09 Oct 2016 10:18 #81453
by FernV
I loaded a new setup.py
It seems it did not remove the link before
Try with arg 'c' first, it will give the name of the link it is trying to create
Fern
Fern
- eFalegname
09 Oct 2016 11:07 #81455
by eFalegname
Hi Fern, sorry for bothering you again this is the last error I get trying to run Linuxcnc:
Thank you
ef@pl ~ $ linuxcnc /home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo/mill-mm.ini
LINUXCNC - 2.8.0-pre1-2638-g7be62e6
Machine configuration directory is '/home/ef/linuxcnc/configs/NativeCAM/configs/sim/axis/ncam_demo'
Machine configuration file is 'mill-mm.ini'
Starting LinuxCNC...
Found file(REL): ./core_sim.hal
Note: Using POSIX non-realtime
Found file(REL): ./sim_spindle_encoder.hal
Found file(REL): ./axis_manualtoolchange.hal
Found file(REL): ./simulated_home.hal
note: MAXV max: 53.340 units/sec 3200.400 units/min
note: LJOG max: 53.340 units/sec 3200.400 units/min
note: LJOG default: 30.480 units/sec 1828.800 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
File "/usr/bin/gladevcp", line 45, in <module>
import gladevcp.makepins
File "/usr/lib/python2.7/dist-packages/gladevcp/__init__.py", line 1, in <module>
from hal_pythonplugin import *
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py", line 1, in <module>
ImportError: No module named ncam
<commandline>:0: waitpid failed gladevcp gladevcp
<commandline>:0: gladevcp exited without becoming ready
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x 60817572 -U --catalog=mill ncam.ui" exited with error: 1
task: 822 cycles, min=0.000010, max=0.009836, avg=0.001133, 0 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/ef/linuxcnc_debug.txt
and
/home/ef/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Thank you
Time to create page: 0.217 seconds
