G-Code error in ncam.ngc Near line 100 only Facing
22 Apr 2022 21:24 - 22 Apr 2022 21:50 #240914
by alfcnc
Replied by alfcnc on topic G-Code error in ncam.ngc Near line 100 only Facing
I have try with ncam -t tab mode...and same problem the gcode failed in Linuxcnc..
So i have try integrate mode of Nativeme cam ncam -i on inifile and here Nativecam integrage mode have working gcod load in Linuxcnc. Very curious.
If i try to export Gcode from Nativecam integrate to Linuxcnc the gcode is good and runnable on Linuxcnc with embedded Nativecam if load in file mode.
Last edit: 22 Apr 2022 21:50 by alfcnc.
22 Apr 2022 21:48 - 22 Apr 2022 21:51 #240920
by alfcnc
without Nativecam embedded ...
I Just come from to understand the problem. This is this post forum.linuxcnc.org/nativecam/43495-run-n...ithout-embeding-ncam of Tjtr33 that help to understand that the Nativecam Gcode generate is not the same that Linuxcnc can Run... so we have to had the new Ocode lib the basic magic M123 code that must be made available to Linuxcnc... After to just add this one line to the Ini file the Gcode is RunableI have try with ncam -t tab mode...and same problem the gcode failed in Linuxcnc..
If i try to export Gcode from Nativecam integrate to Linuxcnc the gcode is good and runnable on Linuxcnc with embedded Nativecam only if load in file mode
Last edit: 22 Apr 2022 21:51 by alfcnc.
22 Apr 2022 23:47 #240943
Replied by andypugh on topic G-Code error in ncam.ngc Near line 100 only Facing
O-sub not found can be caused by wrapping the file in % signs rather than ending with M2.
It's not that is it?
26 Apr 2022 20:56 #241334
by alfcnc
Hi Andypugh.
I have test it before search because i was thinking that this is really juste a problem like M2 or %..but even if i edit the file and change M2 that nativecam have put or % i have always the same errors when open the file..
28 Apr 2022 22:14 #241577
It would seem odd if NativeCAM (written specifically for LinuxCNC) does not produces LinuxCNC G-code (as was suggested a few posts back)
Time to create page: 0.124 seconds
