PathPilot controlled lathe toolchanger
18 Apr 2018 12:53 #109249
by Iron-Man
Replied by Iron-Man on topic PathPilot controlled lathe toolchanger
Updates reported EMCO Tool changer;
www.cnczone.com/forums/benchtop-machines/261754-cnc-3.html
Iron-Man
Iron-Man
23 Jan 2020 05:20 #155504
by Iron-Man
Hello micknucam !
I just wanted to know if you can share your PIC code for the tool changer?
Thanks,
Iron-Man
Thanks,
Iron-Man
23 Jan 2020 11:03 #155531
by micknucam
Replied by micknucam on topic PathPilot controlled lathe toolchanger
Yes No problem
23 Jan 2020 11:25 #155532
by micknucam
Here are the files in various version, the hex file is here just changed the .txt to .hex.
Don't for get i use 4 bits to check the tool position, these are hall effect devices and small magnets 3 bits for 8 tools and a in position bit
Any Problems
Let Me Know
Mike
Any Problems
Let Me Know
Mike
The following user(s) said Thank You: Iron-Man
23 Jan 2020 15:26 #155549
by Iron-Man
Hello Mike
I finally found a "BACK" Turret that just may work without to many modifications.
Thanks !!
Iron-Man
Thanks !!
Iron-Man
20 Apr 2020 23:03 #164897
by smgvbest
Replied by smgvbest on topic PathPilot controlled lathe toolchanger
I've been away for some time but if you truly want this transparent then you need to replicate the toolchanger hardware and not touch the PP code at all.
this is not hard to do. look at the zbot code and you can reverse if from there.
21 Apr 2020 02:56 #164917
by Iron-Man
Hello smgvbest !!
Do you have a link to this "zbot' code?
Thanks,
Iron-Man
Thanks,
Iron-Man
21 Nov 2020 00:27 #189938
by Iron-Man
Hello All !!
Can anyone point me to " zbot code " and you can reverse if from there"
Thanks,
Iron-Man
Thanks,
Iron-Man
21 Nov 2020 00:43 #189939
by Iron-Man
Hello micknucam !!
Can you post your pathpilot files showing your toolchanger interface to pathpilot ?
Thanks,
Iron-Man
Any Problems
Let Me Know
Mike
Hello micknucam !!
Thanks,
Iron-Man
29 Nov 2020 19:22 #190622
by micknucam
Hello IronMan
Sorry for late reply been ill with the corvid bug !
I will sort them out for you I don’t use the turret ! I will get the files off my mate george! There’s also a bit file that has a pwm output.
Moderators: cncbasher
