Setup & Configuring Pathpilot for Lathe. Tutorial2
- cncbasher
- Thank you received: 202
14 Jan 2016 20:11 - 15 Jan 2016 14:14 #68405
by cncbasher
Setup & Configuring Pathpilot for Lathe. Tutorial2 was created by cncbasher
PathPIlot Tutorial Part 2
Configuration for Mill & Startup Errors .
after doing the changes in part1 you may see an error pop up that it needs to change the or update
the software , ignore this and follow on .....
the reason you see an error is that your config files now hold an error
most probably a hal pin error , or you have the 5i25 attached but not the 7i77 for example
the easy way to solve this is to get Pathpilot into what i call desktop mode
and then edit the files or upload a known good one .
i have attached a startup for a 5i25 lathe , i'll attach a mill one shorlty
you'll find most of the gpio pins related to a 7i76 have been hashed out
this is so you can at least get started and edit later ..
to get into desktop mode press left shift & left alt together at the tormach screen
similar fashion to booting to dos etc .
once there you will see the familiar desktop .
the configs are contained in /tmc/configs
and either tormach_lathe or tormach_mill directory as approprate
as pathpilot does not use a config picker
the startup ini file is located in the user operator
and is a file called config_file.txt
if you want to use the files attached below , extract them to
/tmc/configs/tormach_lathe/
and change the startup file in config_file.txt
to ~/tmc/configs/tormach_lathe/tormach_lathe_5i25a.ini
i also found it benifical to make a startup .go.sh script
in operator with :
linuxcnc ~/tmc/configs/tormach_lathe/tormach_lathe_5i25a.ini
i made the file execuitable and it make it easy to startup
whilst in the desktop .
any hal errors or startup errors can be seen in the file pathpilotlog.txt
located in ~operator/gcode/logfiles/
then you can re-run until you have pathpilot running .
the same principals apply to a Mill . but i'll cover that shortly
Thanks to micknucam for the lathe files
in operator with :
Last edit: 15 Jan 2016 14:14 by cncbasher.
The following user(s) said Thank You: brianTruck, dinkata, Rhine_Labs, mikeT, Lcvette
Time to create page: 0.075 seconds
