Lincurve module missing?
- brianbonedoc
04 Apr 2016 02:32 - 04 Apr 2016 03:37 #72670
by brianbonedoc
Lincurve module missing? was created by brianbonedoc
I was trying to dial in the spindle speed of my lathe and when I added the Lincurve line to my hal I received an error that the module isn't installed. I looked in the folder where all the modules are, and sure enough there is no lincurve module installed in PathPilot.
Anyone (like Andy) know how to install it?
Thanks!
EDIT: OK so I just copied the lincurve.ko into the rtlib folder and it seems to work. Now just how to configure it.
The following doesn't really work - the spindle spins at a fixed speed regardless of the commanded rpm.
Here are the important Hal lines:
#added lincurve to correct for spindle actual/commanded differences
# commanded=x actual=y ??
loadrt lincurve personality=4
setp lincurve.0.x-val-00 0
setp lincurve.0.y-val-00 0
setp lincurve.0.x-val-01 200
setp lincurve.0.y-val-01 380
setp lincurve.0.x-val-02 500
setp lincurve.0.y-val-02 650
setp lincurve.0.x-val-03 2400
setp lincurve.0.y-val-03 2400
# added lincurve to correct for RPM differences between commanded and actual
net spindle-speed-raw motion.spindle-speed-out gearchange.0.speed-in
net spindle-speed gearchange.0.speed-out lincurve.0.in
net corrected-spindle-speed incurve.0.out hm2_5i25.0.stepgen.02.velocity-cmd
Thanks!
Last edit: 04 Apr 2016 03:37 by brianbonedoc.
04 Apr 2016 10:00 #72692
by cncbasher
Replied by cncbasher on topic Lincurve module missing?
as you have found some components are missing , but easily added ,
you may find depending on the spindle encoder your using , i.e single or ttl input , you may need to reverse or negate the spindle scale .
this usually shows when the spindle will run the leadin to the cut and then stops waiting for spindle speed to match .
04 Apr 2016 13:01 #72712
A more robust way to install missing components is to find the source-code and then use
sudo halcompile --install lincurve.comp
linuxcnc.org/docs/2.7/html/hal/comp.html
Replied by andypugh on topic Lincurve module missing?
04 Apr 2016 13:02 #72713
I don't see any "addf" line, did you forget it?
- brianbonedoc
04 Apr 2016 14:17 #72717
by brianbonedoc
Replied by brianbonedoc on topic Lincurve module missing?
Andy - yes I did forget the addf!!
Will try to figure it out when I get home later.
Thanks!!
Thanks!!
- brianbonedoc
04 Apr 2016 20:47 #72738
by brianbonedoc
OK, once I added the addf it all worked!! For the path pilot users that may not know how to install the lincurve module the proper way, the drag and drop worked fine as described above.
Thanks Andy!
Here is my current code re: the lincurve and spindle speed. I am within about 20rpm from 200-2400.
# Roughly: commanded RPM=Y actual RPM=X
loadrt lincurve personality=7
addf lincurve.0 servo-thread
setp lincurve.0.x-val-00 150
setp lincurve.0.x-val-01 375
setp lincurve.0.y-val-01 200
setp lincurve.0.x-val-02 650
setp lincurve.0.y-val-02 500
setp lincurve.0.x-val-03 1200
setp lincurve.0.y-val-03 1000
setp lincurve.0.x-val-04 1750
setp lincurve.0.y-val-04 1500
setp lincurve.0.x-val-05 2300
setp lincurve.0.y-val-05 2000
setp lincurve.0.x-val-06 2400
setp lincurve.0.y-val-06 2200
net corrected-speed lincurve.0.out hm2_5i25.0.stepgen.02.velocity-cmd
Thanks Andy!
Moderators: cncbasher
Time to create page: 0.129 seconds
