Use of wizards/conversational with standard LCNC
10 Jul 2016 18:01 - 15 Jul 2016 03:48 #77259
by gmouer
Use of wizards/conversational with standard LCNC was created by gmouer
I have been discussing this with a friend for a while. What would it take to use the pathpilot wizards with the standard LCNC release (2.7). I recall seeing something that the graphics are copyrighted but other than that, what would it take?
Are the wizards normal NCGGUI routines?
Last edit: 15 Jul 2016 03:48 by gmouer.
20 Jul 2016 11:42 #77698
by cncbasher
Replied by cncbasher on topic Use of wizards/conversational with standard LCNC
very quickly , the answers probaly quite a lot of work unfortunatly .
they are embedded into the python gui code , rather than NGCGUI . as well as ngc files
the actual graphics are not the main problem , i have that just about covered
sarah
sarah
20 Jul 2016 11:46 #77699
by gmouer
Replied by gmouer on topic Use of wizards/conversational with standard LCNC
Thanks much for the info ! I guess I will have to go with a full pathfinder install it appears. I would have rather stuck with mainstream LCNC. The conversational part of pathfinder was the only part that really appealed to me.
George
George
20 Jul 2016 14:08 #77719
Have you seen:
Replied by andypugh on topic Use of wizards/conversational with standard LCNC
Have you seen:
20 Jul 2016 20:07 #77734
by gmouer
Yes indeed, I have seen "features" !! A friend and myself have been watching it closely and really want to try it but neither of us have been able to find it nor any instructions for installing it. The install instructions we found are mostly all old broken links.
- cncnoob1979
- Thank you received: 75
24 Jul 2016 16:33 #77912
by cncnoob1979
Replied by cncnoob1979 on topic Use of wizards/conversational with standard LCNC
Linuxcnc Forum: linuxcnc-features-a-kind-of-ngcgui
Here is the link and FernV has a page where you can download it and install it. I currently am using this version as well as many others.
Here is his page with install instructions:
fernv.github.io/linuxcnc-features/
The following user(s) said Thank You: gmouer
27 Jul 2016 11:52 #78065
by cncbasher
Please note :
this is meant to be installed to Axis gui under linuxcnc , this will not install directly to Pathpilot a totally different GUI .
Moderators: cncbasher
Time to create page: 0.165 seconds
