How to change the Pathpilot default g-code folder
- Andyf97
14 Mar 2017 16:02 #89592
by Andyf97
How to change the Pathpilot default g-code folder was created by Andyf97
Does anyone know how to change the default G-code folder
by default this is set to home/operator/g-code
I would like to change it to another drive and folder.
I've searched all over to tried to find some ini with the g-code path but can't find one.
- Thank you received: 1480
14 Mar 2017 16:33 #89598
Replied by Todd Zuercher on topic How to change the Pathpilot default g-code folder
In your ini file in the [DISPLAY] section
linuxcnc.org/docs/html/config/ini-config.html#_display_section
Should be a line:
PROGRAM_PREFIX = ~/linuxcnc/nc_files
That is the default path for your ngc files.
Should be a line:
The following user(s) said Thank You: Skippy1
Time to create page: 0.076 seconds
