- User Interfaces
- PathPilot
- Compiling full LinuxCNC to get realtime components for use with PathPilot 2
- davidimurray
- Thank you received: 5
05 Dec 2019 20:00 #152092
by davidimurray
Replied by davidimurray on topic Compiling full LinuxCNC to get realtime components for use with PathPilot 2
That's great thanks very much - will download it shortly and see how I get on.
- davidimurray
12 Dec 2019 16:20 #152548
by davidimurray
Just to let you know it worked great thanks
30 Dec 2019 07:43 #153542
by DaOne
Replied by DaOne on topic Compiling full LinuxCNC to get realtime components for use with PathPilot 2
How would one get halcompile running on this? I would like to build my own components to run on this.
29 Feb 2020 19:35 #158837
by porshe
Replied by porshe on topic Compiling full LinuxCNC to get realtime components for use with PathPilot 2
Can someone tell where can download the Linuxcnc 2.8.0 ~ pre1 source code for Pathpilot v2.3.6 or other Pathpilot 2 versions to compile the hidcomp component? I have a constant error on different versions of Linuxcnc "This is probably because hidcomp is not compiled for this version "
29 Feb 2020 20:29 #158839
by smgvbest
Replied by smgvbest on topic Compiling full LinuxCNC to get realtime components for use with PathPilot 2
If that does not work post here and I have 2.8.0pre1 i can put on my google drive and share
29 Feb 2020 20:29 #158840
by porshe
Thank you I'll try to compile.
01 Mar 2020 09:53 #158881
by porshe
smgvbest can you put 2.8.0pre1 on google drive? I tried all versions from your link do not fit. I had this when I tried to compile hidcomp on Pathpilot 1.9.8 until I found the source version from this topic forum.linuxcnc.org/pathpilot/29983-notes...ot-1-8-2-source-code
28 Feb 2022 14:33 #236019
by sagreen
operator@tormachpcnc:~/tmc/bin$ ./xhc-hb04
./xhc-hb04: error while loading shared libraries: liblinuxcnchal.so.0: cannot open shared object file: No such file or directory
When I compile 2.8.0-pre1 on a computer running pathpilot 2.8.3 I get the following error complaining about shared memory.. (note, it runs from the command line just fine)
halcmd -i /home/operator/tmc/configs/tormach_mill/tormach_1100-3_sim.ini -f xhc-hb04.hal
sudo dmidecode -s system-product-name: System Product Name
rtapi_shmem_new failed due to shmget(key=0x48414c32): Invalid argument
HAL: ERROR: could not open shared memory
xhc-hb04: ERROR: hal_init failed
xhc-hb04.hal:1: waitpid failed xhc-hb04 xhc-hb04
xhc-hb04.hal:1: xhc-hb04 exited without becoming ready
HALCMD ini file /home/operator/tmc/configs/tormach_mill/tormach_1100-3_sim.ini load failed with config file xhc-hb04.hal
Has anyone got these binaries running on the current version of PathPilot?
Thanks,
Scott...
Replied by sagreen on topic Compiling full LinuxCNC to get realtime components for use with PathPilot 2
I've been trying to compile a linuxcnc 2.8.0-pre1 using all of the examples on this thread. I am able to get the kernel and 2.8.0-pre to compile and successfully run through the tests. But when I move the executable for the xhc-hb04 pendant over to a computer running pathpilot 2.8.3 (current) I get an error complaining about not finding a shared library...Hi,
I pulled 2.8.0-pre1 some time back
if you can't find it here it is from my google drive
2.8.0-pre1
the way I did this was install PP V2 into a virtual machine.
I loaded both PP 2.0.5 source and 2.8.0-pre1 source
installed need dependencies then compiled 2.8.0-pre1, do not install it only compile it from the operator id,
i was then able to pull any libs I needed
compiling pp 2.0.5 from source was fun as the list of prereq was larger as they are not included in the source
hope the 2.8.0-pre1 source helps
Thanks,
Scott...
Moderators: cncbasher
- User Interfaces
- PathPilot
