Wizards with LinuxCNC
11 Jan 2021 15:18 #194916
by Vmax549
Wizards with LinuxCNC was created by Vmax549
Does anyone know if it is possible to build Wizards in LinuxCNC ??? They would probably run in python.
( TP
( TP
11 Jan 2021 15:51 #194920
Replied by cmorley on topic Wizards with LinuxCNC
yes
The original frame work GWiz seems abandoned.
github.com/LinuxCNC/wizards
There are many around:
github.com/LinuxCNC/simple-gcode-generators
linuxcnc.org/docs/2.8/html/gui/ngcgui.html
linuxcnc.org/docs/2.8/html/gui/qtvcp_wid...tml#_macrotab_widget
forum.linuxcnc.org/41-guis/26550-lathe-macros
11 Jan 2021 17:37 #194928
by Vmax549
Replied by Vmax549 on topic Wizards with LinuxCNC
AH the simple gcode generators is what I am looking for. It has all teh basics for a simple wizard/widget. Looking at the Python file IF you take out teh drawing code it gets fairly simple to duplicate code wise.
Just a couple of questions if you have time . Where do you store the Python file and how do you call it into play ?
I am working with PathPilot and this is just an experiment to see IF one can duplicate a Wizard function as we know it work.
Looks promising depending on how you call it into play ( TP
11 Jan 2021 19:45 #194942
by Vmax549
I noticed the teh simple Gcode Gens are written for AXIS I wonder if they will work for PathPilot ?? I have one running from teh desktop but have not figured out how to start it from PathPilot yet.
IF it can be made to run in a simple call from teh MDI in PathPilot that would be the Cats meow . But I fear like all things PathPilot it will be 10xs harder than it needs to be ( Or perhaps we will get lucky and it be simple to use.
( TP
( TP
11 Jan 2021 22:19 #194967
by smgvbest
Replied by smgvbest on topic Wizards with LinuxCNC
PP is going to look for python mainly in ~/tmc/python
simplest way to add to python is in admincmd.py
add a new command there then in the MDI ADMIN WIZNAME
if you got fancy you could add a new tab for wizards and pick the one you want
11 Jan 2021 22:32 #194969
by Vmax549
I ws hoping it would as simple as drop a PY file in a folder then call it from PathPilot MDI . Like everyone else does it ( I will try your method though. Something is always better than nothing.
( TP
( TP
11 Jan 2021 22:56 #194978
by Vmax549
I can see where ADMIN will be handy for a few things but not Wizards.
The wizard would be just as easy to create as others are but teh calling has to be simple as well.
( TP
( TP
11 Jan 2021 23:51 #194990
It works in linuxcnc by outputting the gcode to 'standard output' and the screen reads that output - called filtering in linuxcnc.
It depends if PP kept that same behavior.
Some may allow saving the output to a file - so then it would be a two step process.
( TP
12 Jan 2021 00:27 #194994
by Vmax549
The 2 save options on this Wiz is post to Axis and save to clipboard. Things like save can be worked out through Python BUT I first have to figure out how to load teh WIZ in pathpilot.
I am currently stripping down a Wiz to use as a base model. Getting it down to bare essentials as an example code.
( TP
( TP
12 Jan 2021 15:11 #195062
Does PP support filter programs?
Moderators: cncbasher
Time to create page: 0.094 seconds
