High Low Gearbox Bridgeport
24 Mar 2021 17:24 #203526
by Vmax549
High Low Gearbox Bridgeport was created by Vmax549
DOes anyone here have any experience setting up a 2 speed gear on a bridgeport to run under PathPilot or Linuxcnc ? The spindle direction reverses when you shift to low range and there is a 1:9 reduction in spindle speed.
That will be my next project for the BPCNC mill. Just looking for some example code as a guide.
( TP
( TP
25 Mar 2021 01:50 - 25 Mar 2021 01:50 #203569
Replied by andypugh on topic High Low Gearbox Bridgeport
LinuxCNC has a rather limited 2-gear HAL component. There are others around that do the job better, but this one is the default, and was written (I believe) specifically for Bridgeport mills.
linuxcnc.org/docs/2.8/html/man/man9/gearchange.9.html
Last edit: 25 Mar 2021 01:50 by andypugh.
25 Mar 2021 04:46 #203578
by Michael
Replied by Michael on topic High Low Gearbox Bridgeport
forum.linuxcnc.org/30-cnc-machines/38724...fit?start=120#203548
This post has covered a good amount of gear change, tool change and orient stuff on BP VMC
26 Mar 2021 03:12 #203665
by Vmax549
Replied by Vmax549 on topic High Low Gearbox Bridgeport
I found an example of just about everything rolled into a Hal. Look down near the bottom of the listing. forum.linuxcnc.org/10-advanced-configura...-gearchange-and-near
Moderators: cncbasher
