PathPilot Gear change
06 Apr 2021 14:12 #205116
by J Green
Replied by J Green on topic PathPilot Gear change
Hi again Vmax549
Uploading your code will be quite useful .
Nothing like improving a new wheel vers constantly reinventing a wheel
Trying to attach a File about -- gear cutting with slitting saw on 4 axis mill - trailer
When your mill is done an you are looking for something to machine
Bob
Bob
06 Apr 2021 22:38 #205200
by Vmax549
Replied by Vmax549 on topic PathPilot Gear change
That is pretty cool.
( TP
( TP
07 Apr 2021 15:28 #205260
by Vmax549
It is still working fine AND I have the signal routed to an output that drives a relay that drive the air solenoid to switch gears.
Running it all from the PP hi/low button means that PP takes care of switching gear ratios AND scaling the PWM output for the spindle so that RPMs are corrected in low gear as well as high gear.
So far I have not found a code that will allow me to change gears from a Mcode. Still looking.
( TP
( TP
07 Apr 2021 15:45 #205261
by J Green
Don't know if you are aware that he (AKA = You-Tube skidloaders1 ) included the "G code " for gear cutting with the video . If you are interested -- might want to grab it as my experience is good stuff develops the 404 error just when I need it.
If you are interested in seeing gear cutting without expensive gear cutters also look at You-Tube MuillerNick where hi demo cutting gears using a single HSS straight sided (similar to a HSS threading tool) cutting tool . Nick also shows cutting spiral tooth gears .
Bob
Bob
07 Apr 2021 20:08 #205286
by Vmax549
I seems a long time ago someone ask me about doing a wizard to do that . Probably mach3 stuff. I will take a look at the gcode. May be worth making a new wizard for PP.
Thanks, ( TP
Thanks, ( TP
Moderators: cncbasher
Time to create page: 0.351 seconds
