Spindle direction signal when stopped
08 Apr 2021 04:25 #205306
by rafferty
Spindle direction signal when stopped was created by rafferty
Just about completed a hardware project that gives PathPilot (V1) control of spindle RPM and direction of a SiegSX3 mill.
A limitation of the mill internal software is that the spindle direction can only be changed when the spindle is rotating. What this means is that when the spindle starts it always runs in the direction it was previously then changes direction if required. Not much of a limitation in practice as I can't remember ever running the spindle in reverse.
Not much of a limitation apart from one thing...
Under PathPilot control when the spindle is running forward and is then stopped, the direction line, a gpio out of a 5i25 card, goes from high to low which is a change from forward to reverse, Next press of the PathPilot FWD button sets the line high, forward again.
My hardware faithfully follows the direction line, the spindle starts forward, switches to reverse for a few rotations then back to forward and runs up to speed. I can probably fix my software to eliminate this with a few lines of C but setting direction line to reverse when stopped seems a bit odd.
I can't see where this is happening in PathPilot (I may have missed it) so is it happening LinuxCNC and if it is is it by design?
Is there anyone with a more knowledge of PathPilot and LinuxCNC than I have (which is not much) shed any light on the direction line behaviour?
Ken.
Ken.
09 Apr 2021 10:02 #205412
Replied by andypugh on topic Spindle direction signal when stopped
I would generally anticipate DIR = 1 to be reverse. I suspect that this might be an assumption somewhere in the code. ie spindle-on S=0 has dir = 0.
Can you attach the HAL?
09 Apr 2021 13:43 #205431
by Vmax549
Replied by Vmax549 on topic Spindle direction signal when stopped
I can test that for you if you can tell me what you want to know. I am still in test mode with PP. I can run Halmeter while running PP.
( TP
( TP
09 Apr 2021 13:47 #205432
by rafferty
One thing has just occurred to me, my assumption that the inactive state of motion.spindle-forward implies reverse is wrong. It means spindle is not running forward, motion.spindle-reverse being active is spindle reverse. Either can be active or both can be inactive.
I'll have a poke around and look at both motion.spindle-forward and reverse and if I
find the above to true it's a easy HAL fix.
Thanks, Ken.
Replied by rafferty on topic Spindle direction signal when stopped
I understand that as a logical assumption.I would generally anticipate DIR = 1 to be reverse. I suspect that this might be an assumption somewhere in the code. ie spindle-on S=0 has dir = 0.
The HAL I use is standard PathPilot V1.9.3 unchanged, I won't attach it all given I think I now understand whats going on. The only relevant part is two lines:Can you attach the HAL?
# spindle direction
# P3 pin 16 gpio 005
setp hm2_5i25.0.gpio.005.is_output 1
net spindle-cw motion.spindle-forward => hm2_5i25.0.gpio.005.out
Thanks, Ken.
09 Apr 2021 13:58 #205434
by rafferty
That's very kind of you.
If you can look at the states of motion.spindle-forward and motion.spindle-reverse in the three spindle states, stopped, running forward and running reverse it may confirm the way it works..
I can run the hal monitoring tools myself but by the time I rediscover how to use them again you will most likely have it done.
Thanks for the offer of assistance,
Ken.
( TP
Ken.
09 Apr 2021 15:03 #205439
by Vmax549
stop - For = false Rev = false
forward - For = true Rev = false
reverse - For = false Rev = true
Direction pin
stop = false
forward = true
reverse = false
Transition from forward to stop changes Dirpin = false
Transition from Reverse to stop changes Dirpin = false
Hope that helps, ( TP
Direction pin
stop = false
forward = true
reverse = false
10 Apr 2021 22:55 #205586
by rafferty
Thanks for that TP.
Early this morning (its not 9AM yet) I fired up halshow in a terminal with PP running on another screen and got the same results. I was expecting some 'opposition' from the hal tools but I must have setup this install already.
My plan is to use a set/reset flipflop to latch the motion.spindle-forward and reverse signals and use the f/f output to drive the direction line, that way the direction out will only change when a different motion.spindle signal comes active to what was last active.
Of course PP1 doesn't have the flipflop component so thats next.
Thanks all, Ken.
Thanks all, Ken.
12 Apr 2021 10:19 #205713
by rafferty
Completed my spindle mod and fixed the problem.
I had to reverse the forward and reverse signals setting and resetting the flipflop, as the f/f comes up reset it would have defaulted to reverse. This needs an inversion to get the direction correct, be nice if the ff had an inverted out.
I notice the flipflop output is an 'io' pin not an 'out', does this mean I could preset the output with something likeand go back to plan A without the inversion? Or does this permanently set the ff out to 1, never to change again?
Ken
# spindle direction
# net spindle-cw motion.spindle-forward => hm2_5i25.0.gpio.005.out
net spindle-cw motion.spindle-forward => last-spindle-direction-latch.reset
net spindle-ccw motion.spindle-reverse => last-spindle-direction-latch.set
net spindle-dir-latched last-spindle-direction-latch.out => last-spindle-direction-invert.in
net spindle-motion-dir last-spindle-direction-invert.out => hm2_5i25.0.gpio.005.out
setp last-spindle-direction-latch.out 1
Ken
12 Apr 2021 18:41 #205728
That might explain why it is an IO pin.
It will hold the setp value until the first clock pulse.
(tested)
Note that flipflop does now have an inverted output pin. You wouldn't see that until the next release, but if you want to use the new version early, save the attached file and install with "sudo halcompile --install flipflop.comp"
(tested)
12 Apr 2021 20:22 #205734
by rafferty
The new inverted pin is also 'io'. Does this mean the outputs can be set to an illegal state which will persist until there is clock or set/reset activity?
Ken
Good, I was going to start a campaign.Note that flipflop does now have an inverted output pin.
Looks like the inverted out will also respect the set/reset ins if not clocked.It will hold the setp value until the first clock pulse.
Ken
Moderators: cncbasher
Time to create page: 0.139 seconds
