Bit File for 7i76e
- davidimurray
- Thank you received: 5
14 May 2021 19:00 #208837
by davidimurray
Bit File for 7i76e was created by davidimurray
Hi All
Looking to start setting up my 7i76e with pathpilot. Does anyone know what would be the correct bit file to use to get the full I/O i.e mode 2?
Dave
Dave
14 May 2021 22:11 #208862
Replied by PCW on topic Bit File for 7i76e
Standard firmware should be fine
SSerial modes are set in the hal file
- davidimurray
15 May 2021 08:35 #208896
by davidimurray
Replied by davidimurray on topic Bit File for 7i76e
Thanks PCW.
Do you know which bit file is the standard firmware? I’ve downloaded the pack from the mesanet site but there are a few different versions for the 7i76 in there.
Dave
Dave
15 May 2021 17:43 #208937
The standard firmware is pre-loaded in the 7I76E
the bitfile would be 7i76e_7i76x1d.bit
- davidimurray
15 May 2021 19:00 #208959
by davidimurray
Thanks PCW - now to have a go at getting it working with PP.
I take it nobody has found a way to disable the bit file loading?
Cheers
Dave
Cheers
Dave
04 Jun 2021 01:20 #211117
by yodaddy
Replied by yodaddy on topic Bit File for 7i76e
To avoid bitfile overwriting you need to edit your base or specific .ini file in ~/tmc/configs/tormach_mill and set "BITFILE0=mesa/7i76e_7i76x1D.bit", or whichever 7i76 bitfile you want to use.
09 Jun 2021 23:23 #211655
by crowloy
Replied by crowloy on topic Bit File for 7i76e
or symbolicily link the file to the default bitfile so no changes needed to the ini
Moderators: cncbasher
Time to create page: 0.123 seconds
