4th axis scale factor (steps per degree)
- trueman2001
08 Jun 2021 03:14 #211474
by trueman2001
4th axis scale factor (steps per degree) was created by trueman2001
Hi, I have a new 1100MX and I bought the 4th axis driver kit (stepper driver) and wired up a small ebay 4th axis with a er32 collet.
I just want to learn what the 4th is all about in CAM and in practice before buying into the other more expensive options.
The little 4th is working but the scale is off. I am using the 4" rotary table option available by selecting a radial box in path pilot. I changed the scale in the 4" axis to the correct value in an ini file for the tormach 1100MX But I don't think it was updating. I tried a bunch of edit, restart combinations. I found some similar questions like this for the 440s and the 770s but each seems to have a specific case that complicates the answer. It sounds like the harmonic drive of the 4" might make it more difficult to edit this scale factor. Maybe I should use and edit the 6/8" scale to run this?
Does anyone know the easiest and exact place to edit this scale? Do you need to restart with each change? or can I make edits and check accuracy without the whole reboot.
Also Is the scale factor simply steps per degree?
Any help greatly appreciated!!! Thank you.
- trueman2001
08 Jun 2021 18:32 #211533
by trueman2001
Replied by trueman2001 on topic 4th axis scale factor (steps per degree)
Ok found how to update steps per degree. Chose to use the 4" rotary table selection from user interface.
Go to ~/tmc/config/common/4th_axes.inc
Go to the line that says "SCALE = " under the 4-inch table section; it will be around line 34. The original SCALE value is commented out with a "#". You can restore it at any time by deleting the "#" and commenting out the current value. Then you need to restart the entire machine for the changes to take effect.
Moderators: cncbasher
Time to create page: 0.121 seconds
